3099-20-1-0500-005-1-TS 数据手册
P/N 3099-16-1-0500-0XX-1-TS
(Conductor: Tinned strands)
(Insulation: Silicone Rubber)
UL3099 - Silicone Rubber Wire 150°C 300V (16 AWG)
CONSTRUCTION:
Tinned Strands, copper conductor, 26/0.254mm strands.
Overall Diameter = 3.20mm ± 0.15mm
Insulation Thickness: 0.79mm
CERTIFICATION & APPROVALS:
DUAL-RATED AWM: Can be used in USA and Canada
UL Subject 758 UL FILE NO:E108485
CSA Standard CSA FILE NO:LL84687
Printed Markings:
“AWM 3099 150℃ 300V E108485-S 16AWG REIHSING CSA
I A 150℃ 300V LL84687 16AWG FT2 LF ”
Passes CSA FT2 Vertical Flame Test.
Rated Temperature: 150℃ ~ -30℃
Rated Voltage: 300V
Insulation Potential Strength: 2000 VAC/min
PHYSICAL
ELECTRICAL PROPERTIES:
High flexibility: Soft silicone rubber material.
Maximum Conductor Resistance: 15.6Ω/km
Resistant to: Oil, extremes of hot & cold, flexing.
Silicone rubber wire, has high temperature resistance and
APPLICATIONS:
PACKAGING:
ENVIRONMENTAL APPROVALS:
high flexibility in confined spaces. Suitable for use in whole
sealed cooking appliances, lighting equipment, internal
combustion engine and mercury switches.
500ft per reel.
Conforms to all current RoHS directives as laid out in EU
Directive 2011/65/EC
Current SGS reports for this wire are available upon
request.
P/N's & COLORS
3099-16-1-0500-001-1-TS
3099-16-1-0500-002-1-TS
3099-16-1-0500-003-1-TS
3099-16-1-0500-004-1-TS
3099-16-1-0500-005-1-TS
BLACK
WHITE
YELLOW
RED
BLUE
3099-16-1-0500-006-1-TS
3099-16-1-0500-007-1-TS
3099-16-1-0500-008-1-TS
3099-16-1-0500-010-1-TS
3099-16-1-0500-011-1-TS
BROWN
GREEN
ORANGE
VIOLET
GREEN + YELLOW
3099-20-1-0500-005-1-TS 价格&库存
很抱歉,暂时无法提供与“3099-20-1-0500-005-1-TS”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+129.535801+16.76706
