Additional Resources:
Product Page
3D Model
PCB Footprint
date
04/07/2022
page
1 of 5
MODEL: SJ-3542AS-SMT-TR-67 │ DESCRIPTION: AUDIO JACK
FEATURES
IP67 waterproof
low profile
surface mount
reflow solder compatible
mounting tab
shielded
SPECIFICATIONS
parameter
conditions/description
min
typ
rated input voltage
rated input current
contact resistance1
between terminal and mating plug
between terminal in a closed circuit
insulation resistance
at 500 Vdc
voltage withstand
for 1 minute
-25
life
at a rate of 24 cycles/minute
flammability rating
UL94V-0
RoHS
yes
Note:
1
A
50
30
mΩ
mΩ
MΩ
0.3
operating temperature
units
Vdc
100
insertion/withdrawal force
IP level
max
12
500
Vac
3
kg
85
5,000
°C
cycles
IP67
1. When measured at a current of less than 100 mA/1 kHz
2. All specifications measured at 10~35°C, humidity at 45~85%, under standard atmospheric pressure, unless otherwise noted.
SOLDERABILITY
parameter
reel storage
at relative humidity
SJ-3542AS-SMT-TR-67 价格&库存
很抱歉,暂时无法提供与“SJ-3542AS-SMT-TR-67”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+28.541821+3.45244
- 10+25.8808310+3.13057
- 25+24.5110725+2.96488
- 50+23.9421050+2.89606
- 100+22.80209100+2.75816
- 250+19.95177250+2.41339
