电子发烧友
开通电子发烧友VIP会员 尊享10大特权
海量资料免费下载
精品直播免费看
优质内容免费畅学
课程9折专享价
CES-57175-16L020
CES-57175-16L020
    CUIDEVICES
    SPEAKER, 57.5X17MM ENCLOSURE
CES-57175-16L020 数据手册
Additional Resources: Product Page date 11/01/2019 page 1 of 5 MODEL: CES-57175-16L020 │ DESCRIPTION: SPEAKER ED FEATURES N U • stainless steel plates • 2 speaker channels • 20 mm lead wire SPECIFICATIONS conditions/description input power max power: 1 second on, 59 seconds off, 60 cycles (L/R) impedance at 2.0 kHz, 2.45 Vrms (L/R) 4.8 6.0 7.2 Ω resonant frequency (Fo) at 2.45 Vrms, 10 cm (L/R) 680 850 1,020 Hz frequency response as per IEC 268-5 (L/R) Fo 20,000 Hz sound pressure level at 1.0 W, 10 cm, avg at 0.8, 1.0, 1.5, 2.0 kHz (L/R) 86 92 dB distortion at 2.0 kHz, rated power, 10 cm (L/R) 10 % buzz, rattle, etc. must be normal at sine wave, frequency range (L/R) 2.45 V N typ max units 1.0 1.2 W 89 O polarity min TI parameter cone moves forward w/ positive dc current to “+” terminal dimensions magnet 57.5 x 17 x 5.3 mm Nd-Fe-B PC+ABS IS C enclosure material cone material PEEK terminal wire leads w/ connector weight 5.9 6.9 g operating temperature -30 70 °C -40 85 °C storage temperature RoHS 1. All specifications measured at 15~35°C, humidity at 25~75%, under 86~106 kPa pressure, unless otherwise noted. D Notes: yes cuidevices.com 6.4 Additional Resources: Product Page CUI Devices │ MODEL: CES-57175-16L020 │ DESCRIPTION: SPEAKER date 11/01/2019 │ page 2 of 5 MECHANICAL DRAWING units: mm tolerance: ±0.2 mm D IS C O N TI N U ED wire: UL3302 30 AWG connector: 0800H-04E-46 crimp terminal: CC0801-W08R-04 cuidevices.com Additional Resources: Product Page CUI Devices │ MODEL: CES-57175-16L020 │ DESCRIPTION: SPEAKER date 11/01/2019 │ page 3 of 5 RESPONSE CURVES Frequency Response Curve Total Harmonic Distortion Curve D IS C O Test Conditions: 2.45 Vrms / 10 cm N TI N U ED Test Conditions: 2.45 Vrms / 10 cm cuidevices.com Additional Resources: Product Page CUI Devices │ MODEL: CES-57175-16L020 │ DESCRIPTION: SPEAKER date 11/01/2019 │ page 4 of 5 PACKAGING units: mm IS C O N TI N U ED Tray QTY: 70 pcs per tray Carton Size: 480 x 350 x 450 mm Carton QTY: 2,170 pcs per carton 6 D ITEM: C/NO: MADE IN CHINA cuidevices.com MODEL: Q TY: 2170 PCS N.W: 13.9 Kg G.W: 17 kg 48X35X45cm SIZE: LOT NO Additional Resources: Product Page CUI Devices │ MODEL: CES-57175-16L020 │ DESCRIPTION: SPEAKER date 11/01/2019 │ page 5 of 5 REVISION HISTORY 1.0 description date initial release 11/01/2019 ED rev. D IS C O N TI N U The revision history provided is for informational purposes only and is believed to be accurate. CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website. CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate and reliable. However, no responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may result from its use. CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or effectiveness. cuidevices.com
CES-57175-16L020 价格&库存
很抱歉,暂时无法提供与“CES-57175-16L020”相匹配的价格&库存,您可以联系我们找货
