Additional Resources:
Product Page
3D Model
PCB Footprint
date
11/18/2022
page 1 of 3
MODEL: CRJ025-1-TH | DESCRIPTION: MODULAR JACK
FEATURES
• 6P6C (RJ12)
• gold over nickel plating
• through hole
SPECIFICATIONS
parameter
conditions/description
min
typ
rated voltage
rated current
withstanding voltage
max
units
150
Vac
1.5
for 1 minute
1,500
contact resistance
40
insulation resistance
A
Vac
500
mΩ
MΩ
insertion/withdrawal force
6.12
kgf
operating temperature
-40
85
°C
storage temperature
-40
85
°C
life
1,000
flammability rating
UL94V-0
RoHS
yes
packaging
carton size: 400 x 303 x 258 mm
tray QTY: 100 pcs per tray
carton QTY: 3,000 pcs per carton
cycles
SOLDERABILITY
parameter
wave soldering
for maximum 5 seconds
min
cuidevices.com
typ
max
units
240
°C
Product Page
3D Model
PCB Footprint
CUI DEVICES | MODEL: CRJ025-1-TH | DESCRIPTION: MODULAR JACK
date 11/18/2022 | page 2 of 3
MECHANICAL DRAWING
DESCRIPTION
MATERIAL
PLATING/COLOR
1
insulator
PBT (UL94V-0)
black
2
contact
terminals
phosphor bronze
contact area: 6 µ” gold
over nickel
solder area: matte tin
over nickel
5
4
3
2
1
ITEM
6
units: mm
tolerance:
X ±0.5 mm
X.X ±0.38 mm
X.XX ±0.25 mm
X.XXX ±0.10 mm
PCB: ±0.05 mm
PCB thickness: 1.6 mm
unless otherwise noted
Recommended PCB Layout
Top View
cuidevices.com
Product Page
3D Model
PCB Footprint
date 11/18/2022 | page 3 of 3
REVISION HISTORY
rev.
description
date
1.0
initial release
04/16/2021
1.01
logo, datasheet style update
08/05/2022
updated temperature ranges
11/18/2022
1.02
The revision history provided is for informational purposes only and is believed to be accurate.
CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website.
CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate
and reliable. However, no responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may
result from its use.
CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A
critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life
support device or system, or to affect its safety or effectiveness.
cuidevices.com
很抱歉,暂时无法提供与“CRJ025-1-TH”相匹配的价格&库存,您可以联系我们找货
