Additional Resources:
Product Page
PCB Footprint
date
08/05/2022
page 1 of 3
MODEL: CRJ047-L3-TH | DESCRIPTION: MODULAR JACK
FEATURES
• 8P8C (RJ45)
• 1x4 port
• LED
• shielded
• spring tabs
SPECIFICATIONS
parameter
conditions/description
min
typ
rated voltage
rated current
withstanding voltage
max
units
150
Vac
1.5
for 1 minute
1,500
contact resistance
40
insulation resistance
500
storage temperature
6.12
kgf
°C
-40
80
°C
life
1,000
flammability rating
UL94V-0
RoHS
yes
packaging
carton size: 400 x 303 x 258 mm
tray QTY: 60 pcs per tray
carton QTY: 600 pcs per carton
mΩ
MΩ
insertion/withdrawal force
operating temperature
A
Vac
cycles
SOLDERABILITY
parameter
wave soldering
for maximum 5 seconds
min
cuidevices.com
typ
max
units
240
°C
Product Page
PCB Footprint
CUI DEVICES | MODEL: CRJ047-L3-TH | DESCRIPTION: MODULAR JACK
date 08/05/2022 | page 2 of 3
MECHANICAL DRAWING
units: mm
tolerance:
X ±0.5 mm
X.X ±0.38 mm
X.XX ±0.25 mm
X.XXX ±0.10 mm
PCB: ±0.05 mm
PCB thickness: 1.6 mm
unless otherwise noted
ITEM
DESCRIPTION
MATERIAL
PLATING/COLOR
1
insulator
PBT (UL94V-0)
black
2
contact
terminals
phosphor bronze
contact area: 6 µ” gold
over nickel
solder area: tin over
nickel
3
shield
brass
nickel alloy
Recommended Panel Cutout
LED Schematic
Yellow
LED COLOR
Recommended PCB Layout
Top View
Green
WAVELENGTH
FORWARD VOLTAGE at IF 20 mA
Green
565~575 nm
2.5 V max
Yellow
585~595 nm
2.5 V max
cuidevices.com
Product Page
PCB Footprint
date 08/05/2022 | page 3 of 3
REVISION HISTORY
rev.
description
date
1.0
initial release
04/16/2021
1.01
logo, datasheet style update
08/05/2022
The revision history provided is for informational purposes only and is believed to be accurate.
CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website.
CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate
and reliable. However, no responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may
result from its use.
CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A
critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life
support device or system, or to affect its safety or effectiveness.
cuidevices.com
很抱歉,暂时无法提供与“CRJ047-L3-TH”相匹配的价格&库存,您可以联系我们找货
