Additional Resources:
Product Page
date
08/05/2022
page 1 of 3
MODEL: PJ-003AH | DESCRIPTION: DC POWER JACK
ED
FEATURES
N
U
• 2.0 mm center pin
• 5.0 A rating
• right-angle orientation
• through hole
• open frame
SPECIFICATIONS
conditions/description
rated input voltage
rated input current
typ
contact resistance
at 500 Vdc
for 1 minute
insertion/withdrawal force
operating temperature
at a rate of 24 cycles/minute
flammability rating
UL94V-0
RoHS
yes
O
life
units
Vdc
5
A
50
30
mΩ
mΩ
500
Vac
0.3
3
kg
-25
85
°C
100
N
insulation resistance
voltage withstand
max
24
between terminal and mating plug
between terminal in a closed circuit
1
Note:
min
TI
parameter
MΩ
5,000
cycles
1. When measured at a current of less than 100 mA/1 kHz
2. All specifications measured at 10~35°C, humidity at 45~85%, under standard atmospheric pressure, unless otherwise noted.
SOLDERABILITY
min
typ
max
units
dipped in solder pot for 5 ±0.5 seconds
255
260
265
°C
IS
C
parameter
D
wave soldering
cuidevices.com
Product Page
CUI DEVICES | MODEL: PJ-003AH | DESCRIPTION: DC POWER JACK
date 08/05/2022 | page 2 of 3
MECHANICAL DRAWING
PLATING
center pin
copper
nickel
terminal 1
brass
silver
terminal 2
copper alloy
silver
terminal 3
brass
silver
plastic
PBT
ED
MATERIAL
IS
C
O
N
TI
N
U
units: mm
tolerance:
X.X ±0.2 mm
X.XX ±0.10 mm
X.XXX ±0.050 mm
PCB: ±0.05 mm
Recommended PCB Layout
Top View
D
SCHEMATIC
MATING PLUG
Jack Insertion Depth: 6.5 mm
Model
PJ-003AH
Center Pin
Ø2.0 mm
cuidevices.com
Product Page
date 08/05/2022 | page 3 of 3
REVISION HISTORY
description
date
1.0
initial release
1.01
model change
1.02
applied new spec template
1.03
changed mold design, increased voltage rating
1.04
brand update
1.05
logo, datasheet style update
11/09/2005
ED
rev.
04/03/2006
01/08/2015
02/28/2018
10/30/2019
08/05/2022
D
IS
C
O
N
TI
N
U
The revision history provided is for informational purposes only and is believed to be accurate.
CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website.
CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate
and reliable. However, no responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may
result from its use.
CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A
critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life
support device or system, or to affect its safety or effectiveness.
cuidevices.com
很抱歉,暂时无法提供与“PJ-003AH”相匹配的价格&库存,您可以联系我们找货
