PJ-090H
PJ-090H
    CUIDEVICES
    PWR JACK 1.65X5.9MM VERTICAL THR
PJ-090H 数据手册
Additional Resources: Product Page date 08/05/2022 page 1 of 4 MODEL: PJ-090H | DESCRIPTION: DC POWER JACK ED FEATURES N U • 1.65 mm center pin • 5 A rating • shielded • through hole • vertical orientation • 1 switch SPECIFICATIONS parameter conditions/description min rated input current contact resistance at 500 Vdc between adjacent contacts for 1 minute, 0.5 mA between adjacent contacts insertion/withdrawal force operating temperature at a rate of 24 cycles/minute flammability rating UL94V-0 5.0 A 20 20 mΩ mΩ 500 Vac 0.3 3 kg -25 85 °C RoHS yes MΩ 5,000 O life units Vdc 100 N insulation resistance voltage withstand max 24 between terminal and mating plug between terminal in a closed circuit 1 Note: typ TI rated input voltage cycles 1. When measured at a current of less than 100 mA/1 kHz 2. All specifications measured at 10~35°C, humidity at 45~85%, under standard atmospheric pressure, unless otherwise noted. SOLDERABILITY conditions/description min IS C parameter reel storage at relative humidity
PJ-090H 价格&库存
很抱歉,暂时无法提供与“PJ-090H”相匹配的价格&库存,您可以联系我们找货
