MO063001-4
MO063001-4
    DBUNLIMITED
    100 Hz ~ 8 kHz 模拟 麦克风 驻极体电容 1 V ~ 10 V 全向 (-30dB ±3dB) 导线引线
MO063001-4 数据手册
4 3 2 1 Part Number: DRAWN 3/27/2019 CJ MO063001-4 CHECKED 3/27/2019 C.H. Description: APPROVED Electret Condenser Microphone D 3/27/2019 C.E. This document contains data proprietary to DB Unlimited. Any use or reproduction, in any form, without prior written permission of DB Unlimited is prohibited. All terms and conditions can be found at www.dbunlimitedco.com Top View D Bottom View Side View 3.20 ± 0.20 2.70 ± 0.20 Terminal 2 (-) Terminal 1 (+) Filter (White) Ø7.20 ± 0.20 C 6.00 ± 0.20 C Black Silicon Rubber Mic. 76.20 ± 1.00 Rubber Holder B B WIRE: UL1571, AWG#24 A Items Specifications Directivity Omnidirectional Conditions Sensitivity -30 dB Frequency Range 100 ~ 8,000 Hz Rated Voltage 2 V Voltage Range 1 ~ 10 V Output Impedance 2,200 Ω Max. Rated Current 500 uA IP Rating IP67 Storage Temperature -10 ~ +60 Operating Temperature Signal to Noise Ratio Mount Type Flush Mount Connection Method 4 Lead Wires REVISION HISTORY REV DESCRIPTION DATE APPROVED Released from Engineering 3/27/2019 C.E. NOTES °C 1) All dimensions are in mm unless otherwise noted -10 ~ +60 °C 2) All tolerances are ± 0.5 mm unless otherwise noted 58 dB A 3) All parts meet RoHS 4) Subject to change or redrawn without notice 3 2 1 Additional considerations can be found at www.dbunlimitedco.com/technical-articles.
MO063001-4 价格&库存
很抱歉,暂时无法提供与“MO063001-4”相匹配的价格&库存,您可以联系我们找货
MO063001-4
  • 1+23.992131+3.10782
  • 10+18.2442610+2.36327
  • 25+16.4371225+2.12919
  • 50+15.2177850+1.97124
  • 100+14.10981100+1.82772
  • 300+12.54891300+1.62553
  • 500+11.89637500+1.54100
  • 1000+11.076821000+1.43484
  • 5000+10.034945000+1.29988
库存:56
