SW121108-1
SW121108-1
    DBUNLIMITED
    8 Ohms 通用 扬声器 250 mW 1.1 kHz ~ 10 kHz 顶部 矩形
SW121108-1 数据手册
4 3 2 1 Part Number: DRAWN SW121108-1 7/9/2020 CJ CHECKED 7/9/2020 P.D. Description: APPROVED Waterproof Speaker D 7/9/2020 J.S. D This document contains data proprietary to DB Unlimited. Any use or reproduction, in any form, without prior written permission of DB Unlimited is prohibited. All terms and conditions can be found at www.dbunlimitedco.com Top View Side View Suggested Pad Layout Bottom View 2.8 ± 0.3 Free Position 2 ± 0.15 2 (+) 1.5 2.2 ± 0.3 Working Position 6 ± 0.15 C C 5.4 10.8 12 ± 0.15 9.6 ± 0.1 5.4 5230PSB Sekisui Foam with Double Sided Adhesive (-) B 0.3 3.6 ± 0.1 R0.8 B Side View (2) Release Paper 2.3 Working Position 2.25 Free Position A Items Specifications Conditions Sound Pressure Level 81 dB (@ 0.25W/10cm), In 0.5cc chamber Resonant Frequency 1,100 Hz, In 0.5cc chamber Frequency Range 1,100 ~ 10,000 Hz, In 0.5cc chamber Nominal Power 0.25 W, In 0.5cc chamber Max. Power 0.5 W, In 0.5cc chamber Impedance 8 Ω Cone Material PEEK Mount Type Flush Mount 1) All dimensions are in mm unless otherwise noted IP Rating IPX7 2) All tolerances are ± 0.2 mm unless otherwise noted Storage Temperature -40 ~ +85 °C 3) All parts meet RoHS Operating Temperature -20 ~ +70 °C 4) Subject to change or redrawn without notice 4 REVISION HISTORY REV DESCRIPTION DATE APPROVED Released from Engineering 7/9/2020 J.S. NOTES 3 2 1 Additional considerations can be found at www.dbunlimitedco.com/technical-articles. A
SW121108-1 价格&库存
很抱歉,暂时无法提供与“SW121108-1”相匹配的价格&库存,您可以联系我们找货
