4
3
2
1
Part Number:
DRAWN
3/24/2017
CJ
SW1000304-1
CHECKED
10/6/2017
P.D.
Description:
APPROVED
Waterproof Dynamic Speaker
D
10/6/2017
C.E.
This document contains data proprietary to DB Unlimited. Any use or reproduction, in any form, without prior written
permission of DB Unlimited is prohibited. All terms and conditions can be found at www.dbunlimitedco.com
Top View
Side View (1)
45 ± 0.4
22.5
Bottom View
20.5 ± 1
10
2
36
C
6.5
C
Side View (2)
D
XX X
91 ± 1
100 ± 1.0
83
7
32.5
Date Code Marking
"17 C"
17=2017, C=Mar.
4 - 6.0
Red (+)
Black (-)
22.5
B
150 ± 15
B
A
Items
Specifications
Conditions
Sound Pressure Level
106
dB (@ 10cm), Avg.
Resonant Frequency
350
Hz
Frequency Range
350 ~ 20,000
Hz
Nominal Power
3
Max. Power
2.0 ± 0.5
Wire: UL1571, AWG#26
REVISION HISTORY
REV
DESCRIPTION
DATE
APPROVED
Released from Engineering
10/6/2017
C.E.
1
Add polarity marking, remove connector
10/24/2017
C.E.
W
2
Update markings
2/28/2018
C.E.
5
W
3
Updated tolerances
6/11/2018
C.E.
Impedance
4
Ω
4
Updated dimensions, SPL
8/9/2018
C.E.
Cone Material
Mylar
NOTES
Mount Type
Frame Mount
1) All dimensions are in mm unless otherwise noted
IP Rating
IP67
Storage Temperature
-20 ~ +55
°C
3) All parts meet RoHS
Operating Temperature
-20 ~ +55
4) Subject to change or redrawn without notice
Weight
42.5
°C
g
4
2) All tolerances are ± 0.5 mm unless otherwise noted
3
2
1
Additional considerations can be found at www.dbunlimitedco.com/technical-articles.
A
很抱歉,暂时无法提供与“SW1000304-1”相匹配的价格&库存,您可以联系我们找货
