4
3
2
1
Part Number:
DRAWN
7/9/2020
CJ
SW121308-2
CHECKED
7/9/2020
P.D.
Description:
APPROVED
Waterproof Speaker
D
7/9/2020
J.S.
D
This document contains data proprietary to DB Unlimited. Any use or reproduction, in any form, without prior written
permission of DB Unlimited is prohibited. All terms and conditions can be found at www.dbunlimitedco.com
Top View
Bottom View
Side View (1)
3.05 ± 0.1 Unit
3.46 ± 0.1
2
1.5
5.5 ± 0.1
Suggested Pad Layout
C
5.4
C
10.8
5.4
9.96 ± 0.1
12.00 ± 0.1
5220PSB Sekisui Foam
with Double Sided Adhesive
Release Paper
R1
0.2
B
B
Side View (2)
3.44 ± 0.1 Total height with release paper
0.6 ± 0.15 Free
4.5 Free
4.456 Working
A
Items
Specifications
Conditions
Sound Pressure Level
89
dB (@ 0.4W/10cm), In 2cc chamber
Resonant Frequency
1,300
Hz, In 2cc chamber
Frequency Range
1,300 ~ 20,000
Hz, In 2cc chamber
Nominal Power
0.4
W, In 2cc chamber
Max. Power
0.6
W, In 2cc chamber
Impedance
8
Ω
Cone Material
PEEK
1) All dimensions are in mm unless otherwise noted
Mount Type
Flush Mount
2) All tolerances are ± 0.2 mm unless otherwise noted
IP Rating
IPX8
Storage Temperature
-30 ~ +70
Operating Temperature
-20 ~ +60
4
REVISION HISTORY
REV
DESCRIPTION
DATE
APPROVED
Released from Engineering
7/9/2020
J.S.
NOTES
3) All parts meet RoHS
4) Subject to change or redrawn without notice
°C
°C
3
2
1
Additional considerations can be found at www.dbunlimitedco.com/technical-articles.
A
很抱歉,暂时无法提供与“SW121308-2”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+45.101891+5.81826
- 10+34.4998510+4.45057
- 25+31.1478425+4.01815
- 50+28.8812250+3.72575
- 100+26.81428100+3.45911
- 300+23.89970300+3.08313
- 500+22.67906500+2.92566
- 1000+21.144541000+2.72770
