SW121308-3
SW121308-3
    DBUNLIMITED
    8 Ohms 通用 扬声器 300 mW 1.3 kHz ~ 5 kHz 顶部 矩形
SW121308-3 数据手册
4 3 2 1 Part Number: DRAWN 7/7/2020 CJ SW121308-3 CHECKED 7/9/2020 P.D. Description: APPROVED Waterproof Speaker D 7/9/2020 J.S. D This document contains data proprietary to DB Unlimited. Any use or reproduction, in any form, without prior written permission of DB Unlimited is prohibited. All terms and conditions can be found at www.dbunlimitedco.com Top View Side View Bottom View 5.5 ± 0.1 3 ± 0.1 3.46 ± 0.1 1.66 ± 0.1 (+) C C B 9.44 ± 0.1 12 ± 0.1 9.96 ± 0.1 5220PSB Sekisui Foam with Double Sided Adhesive B R1 (-) Release Paper 2.16 ± 0.1 3.3 ± 0.1 A Items Specifications Conditions Sound Pressure Level 88 dB (@0.3W/10cm), In 2cc chamber Resonant Frequency 1,300 Hz, In 2cc chamber Frequency Range 1,300 ~ 5,000 Hz, In 2cc chamber Nominal Power 0.3 W, In 2cc chamber Max. Power 0.5 W, In 2cc chamber Impedance 8 Ω Cone Material PEEK 1) All dimensions are in mm unless otherwise noted Mount Type Flush Mount 2) All tolerances are ± 0.2 mm unless otherwise noted IP Rating IPX8 Storage Temperature -30 ~ +70 Operating Temperature -20 ~ +60 4 REVISION HISTORY REV DESCRIPTION DATE APPROVED Released from Engineering 7/9/2020 J.S. NOTES 3) All parts meet RoHS 4) Subject to change or redrawn without notice °C °C 3 2 1 Additional considerations can be found at www.dbunlimitedco.com/technical-articles. A
SW121308-3 价格&库存
很抱歉,暂时无法提供与“SW121308-3”相匹配的价格&库存,您可以联系我们找货
