SW150908-1
SW150908-1
    DBUNLIMITED
    8 Ohms 通用 扬声器 500 mW 900 Hz ~ 20 kHz 顶部 矩形
SW150908-1 数据手册
4 3 2 1 Part Number: DRAWN SW150908-1 7/9/2020 CJ CHECKED 7/9/2020 P.D. Description: APPROVED Waterproof Speaker D 7/9/2020 J.S. D This document contains data proprietary to DB Unlimited. Any use or reproduction, in any form, without prior written permission of DB Unlimited is prohibited. All terms and conditions can be found at www.dbunlimitedco.com Side View Top View Bottom View 6 ± 0.15 Suggested Pad Layout 5.8 2 0.35 1 (-) 1.8 Release Paper 2.5 ± 0.15 6.95 6.95 6.95 13.9 15 ± 0.15 11.5 14.9 5290AJB Sekisui Foam with Double Sided Adhesive C 6.95 C B B (+) 0.1 4 - R0.3 Side View (2) 2.5 5.9 A 0.6 ± 0.2 1.75 ± 0.2 Items Specifications Conditions Sound Pressure Level 86 dB (@ 0.5W/10cm), In 2cc chamber Resonant Frequency 1,000 Hz, In 2cc chamber Frequency Range 1,000 ~ 20,000 Hz, In 2cc chamber Nominal Power 0.5 W, In 2cc chamber Max. Power 0.7 W, In 2cc chamber Impedance 8 Ω Cone Material PEEK Mount Type Flush Mount 1) All dimensions are in mm unless otherwise noted IP Rating IPX8 2) All tolerances are ± 0.5 mm unless otherwise noted Storage Temperature -40 ~ +80 °C 3) All parts meet RoHS Operating Temperature -20 ~ +70 °C 4) Subject to change or redrawn without notice 4 REVISION HISTORY REV DESCRIPTION DATE APPROVED Released from Engineering 7/9/2020 J.S. NOTES 3 2 1 Additional considerations can be found at www.dbunlimitedco.com/technical-articles. A
SW150908-1 价格&库存
很抱歉,暂时无法提供与“SW150908-1”相匹配的价格&库存,您可以联系我们找货
