SW151008-1
SW151008-1
    DBUNLIMITED
    8 Ohms 通用 扬声器 500 mW 1 kHz ~ 10 kHz 顶部 矩形
SW151008-1 数据手册
4 3 2 1 Part Number: DRAWN 7/2/2020 CJ SW151008-1 CHECKED 7/9/2020 P.D. Description: APPROVED Waterproof Speaker D 7/9/2020 J.S. D This document contains data proprietary to DB Unlimited. Any use or reproduction, in any form, without prior written permission of DB Unlimited is prohibited. All terms and conditions can be found at www.dbunlimitedco.com Top View Side View 6 ± 0.1 Bottom View Suggested Pad Layout 3.55 ± 0.2 (Free Position) 2.5 ± 0.1 2 1.8 (-) R1.4 C 6.85 C 13.7 12.1 13.7 15 ± 0.1 13 12.8 5240VSB Sekisui Foam with Double Sided Adhesive Release Paper 3.8 B (+) 0.4 B Side View (2) 4 0.65 ± 0.2 1.9 ± 0.2 A Items Specifications Conditions Sound Pressure Level 87 dB (@ 0.5W/10cm), In 2cc chamber Resonant Frequency 1,000 Hz, In 2cc chamber Frequency Range 1,000 ~ 10,000 Hz, In 2cc chamber Nominal Power 0.5 W, In 2cc chamber Max. Power 0.8 W, In 2cc chamber Impedance 8 Ω Cone Material PEEK Mount Type Flush Mount 1) All dimensions are in mm unless otherwise noted IP Rating IPX8 2) All tolerances are ± 0.15 mm unless otherwise noted Storage Temperature -40 ~ +85 °C 3) All parts meet RoHS Operating Temperature -30 ~ +70 °C 4) Subject to change or redrawn without notice 4 REVISION HISTORY REV DESCRIPTION DATE APPROVED Released from Engineering 7/9/2020 J.S. NOTES 3 2 1 Additional considerations can be found at www.dbunlimitedco.com/technical-articles. A
SW151008-1 价格&库存
很抱歉,暂时无法提供与“SW151008-1”相匹配的价格&库存,您可以联系我们找货
SW151008-1
  • 1+24.794081+3.20750
  • 10+19.4766310+2.51960
  • 25+17.7382625+2.29472
  • 50+16.5396750+2.13966
  • 100+15.43475100+1.99672
  • 300+14.99735300+1.94014
库存:248
