SW201308-1
SW201308-1
    DBUNLIMITED
    8 Ohms 通用 扬声器 0.8 W 500 Hz ~ 20000 Hz 顶部 矩形
SW201308-1 数据手册
4 3 2 1 Part Number: DRAWN SW201308-1 2/24/2021 CJ CHECKED 3/10/2021 P.D. Description: APPROVED Waterproof Speaker D 3/10/2021 J.S. D This document contains data proprietary to DB Unlimited. Any use or reproduction, in any form, without prior written permission of DB Unlimited is prohibited. All terms and conditions can be found at www.dbunlimitedco.com Top View Side View Bottom View 21 13 4.87 16.09 1.4 0.60 Ø0.15 C 7.5 C Ø2.0 20 IP67 Double-Sided Adhesive Red Black B 50 ± 3 Wire: UL1571, AWG#32 5±1 Red A Black Items Specifications Conditions Sound Pressure Level 93 ± 3 dB (@ 1W/10cm), Avg. Resonant Frequency 1,300 Hz Frequency Range 500 ~ 20,000 Hz Nominal Power 0.8 W Max. Power 1 W Impedance 8 Ω Cone Material Mylar Mount Type Frame Mount 1) All dimensions are in mm unless otherwise noted IP Rating IP67 2) All tolerances are ± 0.2 mm unless otherwise noted Storage Temperature -25 ~ +75 °C 3) All parts meet RoHS Operating Temperature -25 ~ +75 °C 4) Subject to change or redrawn without notice 4 B REVISION HISTORY REV DESCRIPTION DATE APPROVED Released from Engineering 3/10/2021 J.S. 1 Updated Bottom View 10/21/2021 J.S. 2 Resonant Frequency and Frequency Range 4/13/2022 P.D. NOTES 3 2 1 Additional considerations can be found at www.dbunlimitedco.com/technical-articles. A
SW201308-1 价格&库存
很抱歉,暂时无法提供与“SW201308-1”相匹配的价格&库存,您可以联系我们找货
