SW870508-2
SW870508-2
    DBUNLIMITED
    8 Ohms 通用 扬声器 10 W 500 Hz ~ 7 kHz 顶部 圆形,方形框架
SW870508-2 数据手册
4 3 2 1 Part Number: DRAWN 12/31/2018 CJ SW870508-2 CHECKED 1/7/2019 C.H. Description: D APPROVED Waterproof Speaker 1/7/2019 C.E. This document contains data proprietary to DB Unlimited. Any use or reproduction, in any form, without prior written permission of DB Unlimited is prohibited. All terms and conditions can be found at www.dbunlimitedco.com Top View Side View D Bottom View Ø87 31 ± 1 86 C 71 ± 1 C 6 3.7 5 10 ± 0.3 60 ± 1.5 100.5 ± 1 XX X _ + B B Date Code Marking "19 D" 19=2019, D=Apr. A Items Specifications Conditions Sound Pressure Level 103 dB (1W@10cm), Avg. Resonant Frequency 500 Hz Frequency Range 500 ~ 7,000 Hz Nominal Power 10 W Max. Power 16 W Impedance 8 Ω Cone Material PET Mount Type Frame Mount IP Rating IP67 Storage Temperature -30 ~ +70 °C Operating Temperature -20 ~ +60 Weight 240 °C g Gasket Material NBR5 REVISION HISTORY REV DESCRIPTION DATE APPROVED Released from Engineering 1/7/2019 C.E. 1 Standardized call-out text 8/7/2019 C.E. 2 Updated SPL distance 8/12/2019 C.E. 3 Updated drawing, SPL and added gasket info 8/28/2019 C.E. NOTES 1) All dimensions are in mm unless otherwise noted Gasket Durometer 70 shore A Gasket Temperature Range -30 ~ +180 °C Gasket Thickness 3.0 mm 3) All parts meet RoHS Gasket Width 4 2.0 mm 4) Subject to change or redrawn without notice 3 2) All tolerances are ± 0.5 mm unless otherwise noted 2 1 Additional considerations can be found at www.dbunlimitedco.com/technical-articles. A
SW870508-2 价格&库存
很抱歉,暂时无法提供与“SW870508-2”相匹配的价格&库存,您可以联系我们找货
