SW870508-1
SW870508-1
    DBUNLIMITED
    8 Ohms 通用 扬声器 10 W 390 Hz ~ 7 kHz 顶部 圆形,方形框架
SW870508-1 数据手册
4 3 2 1 Part Number: DRAWN SW870508-1 9/26/2018 CJ CHECKED 9/26/2018 C.H. Description: Waterproof High Temp Speaker D APPROVED 9/26/2018 C.E. This document contains data proprietary to DB Unlimited. Any use or reproduction, in any form, without prior written permission of DB Unlimited is prohibited. All terms and conditions can be found at www.dbunlimitedco.com Top View Side View 87 32 ± 1 71 Bottom View 3.7 C D C 4 - Ø5 10 ± 0.3 60 ± 1.5 Ø100.5 ± 1 XX X _ + B B Date Code Marking "19 D" 19=2019, D=Apr. A Items Specifications Conditions Sound Pressure Level 106 dB (1W@10cm), Avg. Resonant Frequency 390 Hz Frequency Range 390 ~ 7,000 Hz Nominal Power 10 W Max. Power 15 W Impedance 8 Ω Cone Material PEI Mount Type Frame Mount IP Rating IP67 Storage Temperature -40 ~ +85 Operating Temperature -40 ~ +85 Weight 249 Gasket Material NBR5 REVISION HISTORY REV DESCRIPTION DATE APPROVED Released from Engineering 9/26/2018 C.E. 1 Updated SPL 12/31/2018 C.E. °C 2 Updated SPL distance 8/12/2019 C.E. °C g 3 Added gasket info, updated drawing 8/28/2019 C.E. NOTES 1) All dimensions are in mm unless otherwise noted 2) All tolerances are ± 0.5 mm unless otherwise noted Gasket Durometer 70 shore A Gasket Temperature Range -30 ~ +180 °C 3) All parts meet RoHS Gasket Thickness 3.0 mm 4) Subject to change or redrawn without notice Gasket Width 4 2.0 mm 3 2 1 Additional considerations can be found at www.dbunlimitedco.com/technical-articles. A
SW870508-1 价格&库存
很抱歉,暂时无法提供与“SW870508-1”相匹配的价格&库存,您可以联系我们找货
