SW301008-1
SW301008-1
    DBUNLIMITED
    8 Ohms 通用 扬声器 1 W 1.05 kHz ~ 20 kHz 顶部 矩形
SW301008-1 数据手册
4 3 2 1 Part Number: DRAWN 4/10/2021 CJ SW301008-1 CHECKED 4/22/2021 P.D. Description: APPROVED Waterproof Speaker D 4/22/2021 J.S. D This document contains data proprietary to DB Unlimited. Any use or reproduction, in any form, without prior written permission of DB Unlimited is prohibited. All terms and conditions can be found at www.dbunlimitedco.com Top View Side View 17.5 Bottom View 3.7 Ø0.3 Vent Hole C C 8Ω XX X 30 IP67 Double-Sided Adhesive Date Code Marking "21 D" 21=2021, D=Apr. Wire: UL3302, AWG#30 B Black (-) 1.5 Red (+) 100 ± 5 B A Items Specifications Conditions Sound Pressure Level 95 dB (@ 1W/10cm) Resonant Frequency 1,050 Hz Frequency Range 1,050 ~ 20,000 Hz Nominal Power 1 W Max. Power 1.5 W Impedance 8 Ω Cone Material PE Mount Type Flush Mount 1) All dimensions are in mm unless otherwise noted IP Rating IP67 2) All tolerances are ± 0.2 mm unless otherwise noted Storage Temperature -20 ~ +60 °C 3) All parts meet RoHS Operating Temperature -20 ~ +60 °C 4) Subject to change or redrawn without notice 4 REVISION HISTORY REV DESCRIPTION DATE APPROVED Released from Engineering 4/22/2021 J.S. NOTES 3 2 1 Additional considerations can be found at www.dbunlimitedco.com/technical-articles. A
SW301008-1 价格&库存
很抱歉,暂时无法提供与“SW301008-1”相匹配的价格&库存,您可以联系我们找货
