TE054003-6
TE054003-6
    DBUNLIMITED
    磁性 蜂鸣器 传感器,外部驱动 3 V 110mA 4kHz 83dB @ 3V,10cm 表面贴装型 焊盘
TE054003-6 数据手册
4 3 2 1 Part Number: DRAWN 3/20/2022 CJ TE054003-6 CHECKED 3/21/2022 P.D. Description: APPROVED Electro-Mechanical Transducer D 3/21/2022 J.S. D This document contains data proprietary to DB Unlimited. Any use or reproduction, in any form, without prior written permission of DB Unlimited is prohibited. All terms and conditions can be found at www.dbunlimitedco.com Side View Top View C 5.0 Bottom View 45° C 1. 4 2.0 ± 0.2 3.5 3 - 0.8 5.0 Ø0.8 Sound Emission Hole XX X (-) (+) B A Marking 0.35 Date Code Marking "22 C" 22=2022, C=Mar. 1.2 3 - 1.5 2.0 B Items Specifications Conditions Min. Sound Pressure Level 83 dB (@ 10cm) Resonant Frequency 4,000 Hz Rated Voltage 3 V Voltage Range 2~4 V Coil Resistance 12 ± 3 Ω Max. Rated Current 110 mA Storage Temperature -40 ~ +90 °C NOTES Operating Temperature -40 ~ +90 °C 1) All dimensions are in mm unless otherwise noted Connection Method Surface Mount Pads Mount Type Surface Mount 3) All parts meet RoHS Housing Material LCP 4) Subject to change or redrawn without notice Weight 0.1 4 REVISION HISTORY REV DESCRIPTION DATE APPROVED Released from Engineering 3/21/2022 J.S. 2) All tolerances are ± 0.3 mm unless otherwise noted g 3 2 1 Additional considerations can be found at www.dbunlimitedco.com/technical-articles. A
TE054003-6 价格&库存
很抱歉,暂时无法提供与“TE054003-6”相匹配的价格&库存,您可以联系我们找货
