770047
770047
    DESCO
    BOOM ARM, FOR BENCHTOP IONIZER
770047 数据手册
USER GUIDE TB-9109 Benchtop Ionizer Boom Arm Installation Instructions Made in the United States of America Installation 1. Secure the boom arm to the worksurface using its C-clamp. 2. Remove the 4 screws located underneath the 963E Benchtop Air Ionizer's to separate its metal bracket from its plastic base plate. Figure 2. Removing the 4 screws underneath the 963E Benchtop Air Ionizer Figure 1. SCS 770047 Benchtop Ionizer Boom Arm Description The SCS 770047 Benchtop Ionizer Boom Arm is designed as a mounting alternative for the SCS 963E Benchtop Air Ionizer. The boom arm saves valuable workspace by allowing the ionizer to be mounted off the worksurface. The articulated movement of the boom arm allows the user to focus the ionizer’s output directly onto the desired area. The Benchtop Ionizer Boom Arm includes a C-clamp for ease of installation. Packaging 1 Benchtop Ionizer Boom Arm 4 Pan Head Screw, 6/32 x 3/8" 4 Nut, 6-32 Figure 3. Removing the plastic base plate from the 963E Benchtop Air Ionizer 3. Align the boom arm's mounting plate with the hole pattern on the 963E Benchtop Air Ionizer's metal bracket. SCS - 926 JR Industrial Drive, Sanford, NC 27332 East: (919) 718-0000 | West: (909) 627-9634 • Website: StaticControl.com TB-9109 Page 1 of 2 January 2021 © 2021 DESCO INDUSTRIES INC Employee Owned Figure 4. Aligning the boom arm's mounting plate with the 963E Benchtop Air Ionizer's metal bracket 4. Use the 4 included 6-32 pan head screws and nuts to secure the 963E Benchtop Air Ionizer to the boom arm. Figure 6. Using the Benchtop Ionizer Boom Arm with the 963E Benchtop Air Ionizer Specifications Construction Metal with springs Weight 4.8 lbs. (2.2 kg) Max Extension 38" (965 mm) Max Weight Capacity 8 lbs. (3.6 kg) Country of Origin United States of America Limited Warranty, Warranty Exclusions, Limit of Liability and RMA Request Instructions See the SCS Warranty StaticControl.com/Limited-Warranty.aspx Figure 5. Securing the boom arm to 963E Benchtop Air Ionizer's metal bracket 5. Connect the power adapter to the 963E Benchtop Air Ionizer and an appropriate electrical receptacle. SCS - 926 JR Industrial Drive, Sanford, NC 27332 East: (919) 718-0000 | West: (909) 627-9634 • Website: StaticControl.com TB-9109 Page 2 of 2 © 2021 DESCO INDUSTRIES INC Employee Owned
770047 价格&库存
很抱歉,暂时无法提供与“770047”相匹配的价格&库存,您可以联系我们找货
