770079
770079
    SCS
    GROUND MASTER MONITOR ETH
770079 数据手册
USER GUIDE TB-9106 Ground Master Monitor Installation, Operation and Maintenance Made in the United States of America The Ground Master Monitor and its accessories are available as the following item numbers: Item Description 770079 Ground Master Monitor 770064 Power Adapter, 100-240 VAC Input, 7.5 VDC 1.5 A Output, All Plugs 770069 Power Relay, North America CTC065-C Ground Master Extension Cable Unit CTE701 Workstation Monitor Checker 770055 SMP Software Static Management Program Figure 1. SCS 770079 Ground Master Monitor Description The SCS Ground Master Monitor is an equipment ground continuous monitor for metal tools. It continuously monitors the path-to-ground impedance and electromagnetic integrity of eight metal ground connections of process tools in work areas. This includes semiconductor, disk drive, flat panel, and electronic equipment manufacturing environments. The monitor provides both visual and audible alarms and includes fuse protection for each channel. The Ground Master Monitor continuously monitors eight metal tools for electromagnetic interference (EMI). EMI can cause equipment lockups and malfunction. The Ground Master Monitor will alarm if EMI is detected. Each Ground Master Monitor is calibrated with accepted procedures and standards traceable to the National Institute of Standards and Technology (NIST) and includes a certificate of calibration. The Ground Master Monitor meets the Continuous Monitor requirements of ANSI/ESD S20.20 in accordance with ESD TR53. It meets the recommendations of ESD Handbook ESD TR20.20 which includes “if the products that are being produced are of such value that knowledge of a continuous, reliable ground is needed, and then continuous monitoring should be considered or even required”. The SCS 770079 Ground Master Monitor is compatible with SCS Static Management Program (SMP). SMP continuously monitors your ESD process control system throughout all stages of manufacturing. SMP captures data from SCS workstation, equipment and ESD event continuous monitors and provides a real-time picture of critical manufacturing processes. All activity is stored into a database for on-going quality control purposes. SMP allows you to pinpoint areas of concern and prevent ESD events. Quantifiable data allows you to see trends, become more proactive and prove the efficiency of your ESD process control system. SMP is sold separately. Click here to learn more. Packaging 1 1 4 1 1 1 1 1 Ground Master Monitor Monitor Ground Cord (Green and Yellow) Replacement Fuses (250 VAC, 125 mA) Ring Terminal Screw, Pan-Head, 6-32 x 1/4" Star Washer Power Adapter, 12 VDC, with interchangeable plugs (North America, UK/Asia, Europe, China) Certificate of Calibration SCS - 926 JR Industrial Drive, Sanford, NC 27332 East: (919) 718-0000 | West: (909) 627-9634 • Website: StaticControl.com TB-9106 Page 1 of 13 August 2021 © 2021 DESCO INDUSTRIES INC Employee Owned Features and Components A B. Test Limit Rotary Switch: Sets the test limit of the tool monitor circuits from 1 to 20 ohms. B C D E Setting F Test Limit 1 1 ohm 2 2 ohms 3 3 ohms 4 4 ohms 5 5 ohms 6 6 ohms 7 7 ohms 8 8 ohms 9 9 ohms A 10 ohms* B 12 ohms C 14 ohms D 16 ohms E 18 ohms F 20 ohms *default setting G I J L H M C. Power LED: Illuminates yellow when the monitor is powered. K N Figure 2. Ground Master Monitor features and components A. Modbus 3.5 mm Stereo Jack: Outputs Modbus communication protocol which may be used as an alternative to the Ethernet port. Use a 3-conductor cable with a 3.5 mm stereo plug as shown below to access the terminals inside the jack. Note: The Ground Master Monitor and external Modbus device must utilize the same ground. Plug Contact Color Code Modbus Contact Tip Red TR- Center White TR+ Base Green Ground D. Tool LEDs: Illuminates green when its respective tool is within the impedance and electromagnetic interference (EMI) voltage test limits. Blinks red when its respective tool exceeds the EMI voltage limit. Illuminates solid red and audible alarm sounds when its respective tool exceeds the impedence test limit. E. Tool Monitor Switches: Slide the switch up to enable its respective tool monitor circuit. Slide the switch down to disable its respective tool monitor circuit. F. Audible Alarm Switch: Enables and disables the monitor's audible alarm. G. Communication LED: Blinks when the monitor is powered and communicating to SMP Server. H. Protective Fuses: Protects the spread of harmful voltage to other tools via the Ground Master Monitor should one of the tools become exposed to excessive voltage. The appropriate fuse will disconnect the faulty tool from the Ground Master Monitor and from the other connected tools. SCS - 926 JR Industrial Drive, Sanford, NC 27332 East: (919) 718-0000 | West: (909) 627-9634 • Website: StaticControl.com TB-9106 Page 2 of 13 © 2021 DESCO INDUSTRIES INC Employee Owned I. Optical Relay Terminals: Integrates with electronic tools, lights, buzzers, etc. The relay opens when the monitor enters a ground alarm condition, and it remains closed otherwise. Relay Parameter Rating Peak Blocking Voltage 400 VP Load Current On-Resistance (max) 140 mArms / mADC 22 ohms J. Power Relay Terminals: For use ONLY with the SCS 770069 Power Relay. Use the Power Relay to control power to workbenches, hand tools, and other electronic devices when the Ground Master Monitor passes or fails. 6. Connect an Ethernet cable to the Ethernet jack located on the bottom-side of the Ground Master Monitor. Verify that the cable is properly connected to a network. 7. Connect the power adapter to the power jack located on the bottom-side of the Ground Master Monitor. Route the wire from the supply to a nearby AC outlet and plug it into the outlet. Make sure the voltage and frequency match those listed on the power supply. The Ground Master Monitor is now powered. K. Monitored Tool Terminals: Monitors metal tools for proper conductive impedance and electromagnetic interference (EMI) voltage. Use 18 AWG wire to connect the metal tools to these terminals. L. Ethernet Jack: Provides network communication between the Ground Master Monitor and Static Management Program (SMP). Grounded Metal Tool Tool Monitor Wire (not included) M. Power Jack: Connect the included 7.5 VDC power adapter here. N. Ground Terminal: Common ground point for the monitor. Installation Monitor Ground Cord Hardware Setup 1. Remove the Ground Master Monitor from the carton, and inspect for damage. 2. Determine the mounting location of the Ground Master Monitor, and use its mounting tabs to secure it. Its display should be visible to the operator(s). 3. Secure one end of the included ground cord to the ground terminal located on the bottom-side of the Ground Master Monitor. Attach the other end of the cord to a ground point. The face plate screw of a grounded AC wall outlet may provide a convenient connection point. Ethernet Network Cable Power Adapter Figure 3. Wiring the Ground Master Monitor to two metal tools 4. Insert stripped terminations of 18 AWG wires (not included) into the monitored tool terminals located on the bottom-side of the Ground Master Monitor. Ensure that the tool monitor switches are enabled if using these monitored tool terminals. 5. Route the tool monitor wires from the bottom-side of the Ground Master Monitor to their respective grounded metal tools, and secure them. Keep the wires as short as possible. Do not loop or coil them as it may affect the measured impedance. Figure 4. Mounting hole locations (all dimensions are in inches) SCS - 926 JR Industrial Drive, Sanford, NC 27332 East: (919) 718-0000 | West: (909) 627-9634 • Website: StaticControl.com TB-9106 Page 3 of 13 © 2021 DESCO INDUSTRIES INC Employee Owned SMP Network Setup The following procedure outlines how to connect the Ground Master Monitor to SMP via a local area network (LAN). SMP must be installed to a PC prior to using this procedure. The diagram shown below illustrates a common SMP system setup that utilizes the server software, client software, WS Aware Monitor, EM Aware Monitor, and Ground Master Monitor. Customer’s Network SMP Server Network Switch SMP Client WS Aware WS Aware Ground Master SMP Client EM Aware SMP Client EM Aware Figure 6. SMP system setup SCS - 926 JR Industrial Drive, Sanford, NC 27332 East: (919) 718-0000 | West: (909) 627-9634 • Website: StaticControl.com TB-9106 Page 4 of 13 © 2021 DESCO INDUSTRIES INC Employee Owned DYNAMIC IP PROCEDURE 1. Verify that the Ethernet cable is securely connected to your network and Ground Master Monitor. The LEDs on the Ethernet port will illuminate when a connection to the network is established. 2. Open SCS SMP Server Monitor. 3. The SMP Server icon will appear in the Windows taskbar. 4. Click the SMP Server icon located on the Windows taskbar. The SMP Server menu will appear. Click the Start button to start SMP Server. SCS - 926 JR Industrial Drive, Sanford, NC 27332 East: (919) 718-0000 | West: (909) 627-9634 • Website: StaticControl.com TB-9106 Page 5 of 13 © 2021 DESCO INDUSTRIES INC Employee Owned 5. A message will appear and display “Starting SMP Server…” Click the SMP Server icon located in the Windows taskbar. 6. SMP Server will now indicate Active server status. 7. SMP Server will search and find the Ground Master Monitor on the network. The Device and Active counts will increase to 1. SCS - 926 JR Industrial Drive, Sanford, NC 27332 East: (919) 718-0000 | West: (909) 627-9634 • Website: StaticControl.com TB-9106 Page 6 of 13 © 2021 DESCO INDUSTRIES INC Employee Owned 8. Open SCS SMP Admin. 9. The window for SMP Server Admin will appear. “1 unassigned” is representative of the Ground Master Monitor that was just found by SMP Server. Click the Add New Building button. SCS - 926 JR Industrial Drive, Sanford, NC 27332 East: (919) 718-0000 | West: (909) 627-9634 • Website: StaticControl.com TB-9106 Page 7 of 13 © 2021 DESCO INDUSTRIES INC Employee Owned 10. Enter a building name, and then click the OK button. 11. The building name will appear on the navigation pane in SMP Server Admin. 12. Click on the building name in the navigation pane, and then click the Add New Floor button. SCS - 926 JR Industrial Drive, Sanford, NC 27332 East: (919) 718-0000 | West: (909) 627-9634 • Website: StaticControl.com TB-9106 Page 8 of 13 © 2021 DESCO INDUSTRIES INC Employee Owned 13. Enter a floor name, and then click the OK button. 14. The floor name will appear on the navigation pane in SMP Server Admin. 15. Click on the floor name in the navigation pane, and then click the Add New Line button. SCS - 926 JR Industrial Drive, Sanford, NC 27332 East: (919) 718-0000 | West: (909) 627-9634 • Website: StaticControl.com TB-9106 Page 9 of 13 © 2021 DESCO INDUSTRIES INC Employee Owned 16. Enter a line name, and then click the OK button. 17. The line name will appear on the navigation pane in SMP Server Admin. 18. Click on the line name in the navigation pane, and then click the Attachable Devices arrow located at the bottom of the window. SCS - 926 JR Industrial Drive, Sanford, NC 27332 East: (919) 718-0000 | West: (909) 627-9634 • Website: StaticControl.com TB-9106 Page 10 of 13 © 2021 DESCO INDUSTRIES INC Employee Owned 19. The serial number for the Ground Master Monitor will appear. Click attach. 20. The Ground Master Monitor will attach to the selected line. SCS - 926 JR Industrial Drive, Sanford, NC 27332 East: (919) 718-0000 | West: (909) 627-9634 • Website: StaticControl.com TB-9106 Page 11 of 13 © 2021 DESCO INDUSTRIES INC Employee Owned 21. Open SCS SMP Client. 22. Verify that the Ground Master Monitor was added to the appropriate building, floor and line. SCS - 926 JR Industrial Drive, Sanford, NC 27332 East: (919) 718-0000 | West: (909) 627-9634 • Website: StaticControl.com TB-9106 Page 12 of 13 © 2021 DESCO INDUSTRIES INC Employee Owned Operation Use the table below to interpret the behavior of the Ground Master Monitor's tool LED's and audible buzzer (if enabled). Green LED Red LED Buzzer Status ON OFF OFF No failures OFF ON ON Impedance failure ON BLINK OFF EMI voltage failure OFF OFF OFF Monitor channel disabled Maintenance Cleaning Disconnect the power adapter from the device. Clean the Ground Master Monitor using a dry brush or vacuum cleaner. Clean its contacts using a contact cleaner or brush, and tighten all connections. Do not reconnect the power adapter until cleaning is finished. Replacing the Fuses The monitored equipment may become prone to excessive voltage and significant damage should it lose its connection to ground or be bonded to an improperly wired ground point. In order to prevent the spread of this excessive voltage to other equipment via the Ground Master Monitor, fuses are implemented for each individual ground connection. In the case of excessive voltage on the equipment, the appropriate fuse will disconnect the equipment from the Ground Master Monitor and from the other connected equipment. Ground failure on that particular ground will be immediately indicated. Figure 7. SCS CTE701 Workstation Monitor Checker Specifications Power Power Adapter 100-240 VAC 50-60 Hz Output: 12 VDC @ 1.5 A Output Plug Polarization: Center Positive Output Plug: 5.5 mm O.D. x 2.1 mm I.D. x 9.5 mm L Metal Tool Amount Monitored 8 Impedance Limit 10 ohms (default) EMI Voltage Limit 223 mV average amplitude (@ 1.5 MHz) Test Voltage 80 mV square pulse @ open circuit (80 Hz) NOTE: Never use wire jumpers in place of fuses. Use only factory-authorized fuses. Disconnect power before replacing any fuses. The fuses are manufactured by Littelfuse®, and its part number is 37301250410. Test Current
770079 价格&库存
很抱歉,暂时无法提供与“770079”相匹配的价格&库存,您可以联系我们找货
