770789
770789
    SCS
    耗散 桌子,工作台卷筒 接地垫 人造橡胶 透明 50'(15.24m) X 24"(.61m)2'
770789 数据手册
Specifications Electrical Properties Surface Resistance: Volume Resistance: Static Decay Rate: +5000 V to 50 V -5000 V to -50 V +1000 V to 100 V Physical Properties 0.040" Construction: Filler: Thickness: Temperature: Color:* Specific Gravity: Typical Values 1 x 106 to < 1 x 109 ohms 1 x 106 to < 1 x 109 ohms 0.01 Seconds 0.01 Seconds 0.1 Seconds Test Procedures/Method ESD S11.12 FTMS-101C (12% R.H.) Charged Plate Monitor (50% R.H.) TPU Alloy Inherently Dissipative Polymer (IDP) 0.040” (1.0mm) 190°F (87°C) Transparent 1.16 g/cc Mechanical Properties Tensile Strength at Break: Ultimate Elongation, Break: Modulus at 100%: Modulus at 300%: Shore Hardness 3800 (26) Psi (MPa) 450% 1200 (8) Psi (MPa) 2200 (15) Psi (MPa) 90A / 47 D ASTM ASTM ASTM ASTM ASTM D-412 D-412 D-412 D-412 D-412 Tolerances Width: = ± 0.250” Length: = ± 0.250” per linear foot Thickness: = ± 10% RoHS, REACH, and Conflict Minerals Statement See the Desco Industries RoHS, REACH, and Conflict Minerals Statement: http://www.descoindustries.com/pdf/Regulatory.pdf See the SCS Limited Warranty: https://staticcontrol.descoindustries.com/Limited-Warranty.aspx Made in the United States of America *Color and texture may vary between lots and mills. Specifications and procedures subject to change without notice. C10 Series Clean ESD Thermoplastic Polyurethane Mat, 0.040” (1.0MM) 926 JR Industrial Drive, Sanford, NC 27332 WEB SITE: StaticControl.com PHONE (919) 718-0000 © 2021 DESCO INDUSTRIES INC Employee Owned DRAWING C10 Series DATE: December 2021
770789 价格&库存
很抱歉,暂时无法提供与“770789”相匹配的价格&库存,您可以联系我们找货
