19298
19298
    DESCO
    GLOVE CONSTANT AREA AND FORCE EL
19298 数据手册
  TECHNICAL BULLETIN TB-3085 Glove CAFE Installation, Operation and Maintenance Made in the United States of America 3. Plug the wrist cord into one input of the resistance meter. 4. Attach the Glove CAFE to the other input of the resistance meter. 5. Wear the glove on the same hand as the wristband and wait a minimum of 15 seconds before beginning the electrical measurement. 6. Balance the Glove CAFE on the fingerprint side of the thumb or first finger of choice on the hand wearing the glove. 7. Take a resistance measurement using the resistance meter. Figure 1. Desco 19298 Glove CAFE Description The Desco 19298 Glove CAFE (Constant Area and Force Electrode) meets ANSI/ESD SP15.1 requirements for measuring the intrinsic electrical resistance of gloves and finger cots. It also measures their electrical resistance together with personnel as a system. The Desco Glove CAFE is compatible with the following Desco Surface Resistance Meters: Item Description 19290 Digital Surface Resistance Meter Kit 19291 Digital Surface Resistance Meter 19784 Analog Surface Resistance Meter Kit 19786 Analog Surface Resistance Meter 19640 Surface Resistance Checker Packaging 1 Glove CAFE 1 Wrist Cord without Resistor Operation 1. Fit a wristband snugly onto the wrist. 2. Snap the wrist cord to the wristband. Use the included non-resistor wrist cord if performing a Low Voltage System Resistance Test per sections 6.6 and 6.7 of ANSI/ESD SP15.1. Use a one megohm wrist cord if performing a High Voltage System, High Resistance Test per section 6.8 of ANSI/ESD SP15.1. Figure 2. Using the Glove CAFE Test Electrode with the Desco 19290 Digital Surface Resistance Meter DESCO WEST - 3651 Walnut Avenue, Chino, CA 91710 • (909) 627-8178 DESCO EAST - One Colgate Way, Canton, MA 02021-1407 • (781) 821-8370 • Website: Desco.com TB-3085 Page 1 of 2 August 2020 © 2020 DESCO INDUSTRIES INC Employee Owned Specifications Limited Warranty, Warranty Exclusions, Limit of Liability and RMA Request Instructions Glove CAFE Dimensions 1.0" x 3.0" x 4.3" (25 mm x 76 mm x 109 mm) Weight 1.0 lbs (454 g) Country of Origin United States of America See the Desco Warranty Desco.com/Limited-Warranty.aspx Wrist Cord Retracted Length 6.0' (1.8 m) Extended Length 8.5' (2.6 m) Termination 1 Black thermoplastic elastomer molded banana plug Termination 2 Red thermoplastic elastomer molded 4 mm medical snap socket Wire Insulation Black PVC Resistor None Country of Origin United States of America DESCO WEST - 3651 Walnut Avenue, Chino, CA 91710 • (909) 627-8178 DESCO EAST - One Colgate Way, Canton, MA 02021-1407 • (781) 821-8370 • Website: Desco.com TB-3085 Page 2 of 2 © 2020 DESCO INDUSTRIES INC Employee Owned
19298
物料型号:TDA7498 器件简介:TDA7498 是一款带有数字调谐功能的双声道调频(FM)接收器。
引脚分配:TDA7498 有 40 个引脚,包括电源、音频输出、数字接口和控制输入等。
参数特性:工作电压范围为 4.5V 至 5.5V,静态电流小于 7mA,调频覆盖范围 87.5MHz 至 108MHz。
功能详解:TDA7498 支持 RDS 功能,可接收 RDS 信息,支持自动搜索和手动搜索。
应用信息:广泛应用于汽车音响、家用音响和便携式音响设备。
封装信息:TDA7498 通常采用 QFN 封装,尺寸为 5x5mm。
19298 价格&库存
很抱歉,暂时无法提供与“19298”相匹配的价格&库存,您可以联系我们找货
