1.10.107.011/0507
1.10.107.011/0507
    RAFI
    按钮开关 SPST-NO 标准 前面板安装
1.10.107.011/0507 数据手册
10.10.2016 Pushbutton non-illuminated - mounting hole diameter 9.1 mm, green 1.10.107.011/0507 General information Form of lens Color of lens Form of collar protruding lens opaque green round Dimensions Diameter of collar Overall height Mounting depth Mounting hole 11 mm 4.5 mm 25.5 mm 9.1 mm Mechanical design Mounting Terminals Contact system Contact function Contact arrangement Contact materials Illumination Lamp socket ring nut solder terminals bridge contact momentary 1 NO Ag no no Mechanical characteristics Operating force max. Operating travel Switching travel NO Robustness max. 7N 2 mm 1.3 mm 100 N Electrical characteristics Rated voltage AC max. Rated voltage DC max. Rated current max. Contact resistance max. 24 V 24 V 0.1 A 200 mΩ Other specifications Operating life (operations) Degree of protection from front side Operation temperature min. Ambient temp. operating max. Storage temperature min. Storage temperature max. Environmental restistance 40,000 cycle IP40 (DIN EN 60529) -25 °C +70 °C -40 °C +80 °C acc. to IEC 60068-2-14, -30, -33 and -78 Technical data are approximate and intended solely for general orientation in the selection of a product. Subject to modifications and errors. Images and other graphics may only be similar. For more information, refer to www.rafi.de chapter Imprint / Data Protection. 10.10.2016 Weight Soldering time max. Soldering temperature max. ROHS compliant REACH compliant 2g 3s 350 °C yes yes Panel cut-out Technical data are approximate and intended solely for general orientation in the selection of a product. Subject to modifications and errors. Images and other graphics may only be similar. For more information, refer to www.rafi.de chapter Imprint / Data Protection.
1.10.107.011/0507
1. 物料型号:1.10.107.011/0507 2. 器件简介: - 形式:突出镜头 - 颜色:不透明绿色 - 领口形状:圆形 - 尺寸:领口直径11mm,总高度4.5mm,安装深度25.5mm,安装孔9.1mm 3. 引脚分配:焊接端子 4. 参数特性: - 操作力最大:7N - 操作行程:2mm - 开关行程NO:1.3mm - 耐用性最大:100N 5. 功能详解: - 接触系统:桥接接触 - 接触功能:瞬时 - 接触排列:1NO - 接触材料:Ag(银) 6. 应用信息: - 额定电压AC最大:24V - 额定电压DC最大:24V - 额定电流最大:0.1A - 接触电阻最大:200毫欧 - 操作寿命:40,000次 - 前部防护等级:IP40 - 工作温度范围:-25°C 至 +70°C - 存储温度范围:-40°C 至 +80°C - 环境抗性:符合IEC60068标准 7. 封装信息: - 重量:2g - 最大焊接时间:3秒 - 最大焊接温度:350°C - 符合RoHS和REACH标准
1.10.107.011/0507 价格&库存
很抱歉,暂时无法提供与“1.10.107.011/0507”相匹配的价格&库存,您可以联系我们找货
1.10.107.011/0507
  • 17+53.91378
  • 50+38.05039
库存:10
1.10.107.011/0507
  • 1+71.573811+8.96667
  • 10+61.7869110+7.74058
  • 30+57.5892030+7.21470
  • 50+55.7312850+6.98194
  • 100+53.30122100+6.67750
  • 250+50.24613250+6.29477
  • 500+48.04734500+6.01931
  • 1000+45.940601000+5.75538
库存:21
1.10.107.011/0507
    • 8+103.277848+12.93850
    • 40+92.9049640+11.63900
    库存:10
