CC150SA110
CC150SA110
    CARLOGAVAZZI
    3P CONT S 110V 50/60HZ 2NO2NC
CC150SA110 数据手册
CARLO GAVAZZI Automation Components Table of Specifications Midi-Contactors Midi 3-Pole Magnetic Contactors CC9 Terminal type CC12 CC18 CC22 CC32 CC40 Screw Only Screw Only GUA1, GUA2, GUA4 GUA-1 GUA-2, GUA-4 GUA-1 GUA-2, GUA-4 GT Type Thermal Overload Relays GT32 GT32 To instantly view a data sheet and specify products, visit www.GavazziOnline.com 10 CARLO GAVAZZI Automation Components Table of Specifications CC50 CC65 CC75 CC85 Screw or Lug CC100 Screw or Lug GUA-1 GUA-2, GUA-4 GUA-1 GUA-2, GUA-4 GT63 GT95 Specifications are subject to change without notice. 11 CARLO GAVAZZI Automation Components Table of Specifications CC265* CC330* CC400* CC500* CC630* Screw Only Screw Only GT400 GT800 Specifications are subject to change without notice. 13 CC800* CARLO GAVAZZI Automation Components Type Numbering System Midi-Contactor Overload CC 9 Magnetic 3-pole Midi -Contactor Amperage Size 9 - 9A 12 - 12A 18 - 18A 22 - 22A 32 - 32A 40 - 40A 50 - 50A 65 - 65A 75 - 75A 85 - 85A 100 - 100A Type BLANK 3-pole /4 - 4-pole S A 120 Terminal Type Coil Type Coil Voltage S - Screw L - Lug (>50A) A - AC type D - DC type 24 - 24V 120 - 120V & 600 - 600V AC Coil Frequency Auxiliary Contact s BLANK - 50/60 Hz 50Hz - 50Hz only 60Hz - 60Hz only BLANK - standard arrangement NOAUX - no aux. contact (>=32A) GT 32 Bimetallic Midi-Overload Frame Size Class 22 3P 22A Electronic Midi Overload Frame Size Protection Setting Range GUA2 GUA4 GUW32 GUZ32 GTTRR-16 16 400 20 500 24 600 To instantly view a data sheet and specify products, visit www.GavazziOnline.com 14 0.1 ~ 0.16A 0.16 ~ 0.25A 0.25 ~ 0.4A 0.4 ~ 0.63A 0.63 ~ 1A 1 ~ 1.6A 1.6 ~ 2.5A 2.5 ~ 4A 4 ~ 6A 5 ~ 8A 6 ~ 9A 7 ~ 10A 9 ~ 13A 12 ~ 18A 16 ~ 22A 18 ~ 25A 22 ~ 32A 24 ~ 36A 28 ~ 40A 34 ~ 50A 45 ~ 65A 54 ~ 75A 63 ~ 85A 70 ~ 95A 80 ~ 100A CGE GUA1 GUR02 (Use upper limit in part ) S - Screw L - Lug (≥35A) Tunel Type 22 and 40AF 2T - 2-Pole 3T - 3-Pole 3TR - 3-Pole GUS11 (Must match contactor number) BLANK class 10 L - class 20 Separate Mount All CGE sizes 2S - 2-Pole 3S - 3-Pole 3SR - 3-Pole – 0.16A Setting Ranges 32 - 9, 12, 18A 22, 32, 40A 65 - 50, 65A 75 - 75, 85, 100A 22 - 9, 12, 18, 22A Direct Mount 40 - 32, 40A 22 and 40AF 80 - 50, 65, 75, 85A 2P - 2-Pole 3P - 3-Pole 3PR -3-pole GUA1 S Terminal Type (Use upper limit in part ) CGE22 0.3 ~ 1.5A 1 ~ 5A 4.4 ~ 22A CGE40 4 ~ 20A 8 ~ 40A CGE80 16 ~ 80A (Setting Range Guide) GT32 GT65 GT95 CARLO GAVAZZI Automation Components Environment //Connections CC9 CC12 CC18 CC22 CC32 CC40 CC50 CC65 CC75 CC85 CC100 CC130 CC150 CC9~150 CC185 CC225 CC265 CC330 CC400 CC500 CC630 CC800 CC185~800 To instantly view a data sheet and specify products, visit www.GavazziOnline.com 16 CARLO GAVAZZI Automation Components Control Coil Charactoristics CC9 CC32 CC50 CC12 CC40 CC65 CC12 CC75 CC130 CC85 CC150 CC100 CC22 To instantly view a data sheet and specify products, visit www.GavazziOnline.com 18 CARLO GAVAZZI Automation Components Control Coil Charactoristics CC185 CC265 CC500 CC225 CC330 CC630 CC400 CC800 Specifications are subject to change without notice. 19 CARLO GAVAZZI Automation Components Internal Structure Specifications are subject to change without notice. 21 CARLO GAVAZZI Automation Components Contactors (150AF) - 2NO2NC Auxiliary contacts built-in as standard CC130 CC150 CC150 GT150 Coil Voltage To instantly view a data sheet and specify products, visit www.GavazziOnline.com 32 CARLO GAVAZZI Automation Components Contactors (150AF) GUS Interlock unit, GUR02 GUA1 GUA4 GUA2 GT CC Specifications are subject to change without notice. 33 CARLO GAVAZZI Automation Components Contactors (150AF ~ 800AF) CC130 ~ CC150 2NO2NC aux CC185 ~ CC225 2NO2NC aux CC265 ~ CC400 2NO2NC aux CC500 ~ CC800 2NO2NC aux To instantly view a data sheet and specify products, visit www.GavazziOnline.com 90 CARLO GAVAZZI Automation Components Motor Starters (65AF ~ 150AF) CC50 ~ CC65 with GT63 shown with no aux contact CC75 ~ CC100 with GT95 shown with no aux contact CC130 ~ CC150 with GT150 shown with no aux contact To instantly view a data sheet and specify products, visit www.GavazziOnline.com 92 CARLO GAVAZZI Automation Components Reversing Contactors and Starters (150AF ~ 800AF) CC130 ~ CC150 AC coil reversing combination shown with aux contacts CC185 ~ CC225 reversing combination shown with aux contacts CC265 ~ CC400 reversing combination shown with aux contacts CC500 ~ CC800 reversing combination shown with aux contacts Specifications are subject to change without notice. 99 CARLO GAVAZZI Automation Components Reversing Contactors and Starters (150AF ~ 400AF) CC130 ~ CC150 AC coil reversing combination shown with GT150 and aux contacts CC185 ~ CC225 AC coil reversing combination shown with GT225 and aux contacts CC265 ~ CC400 AC coil reversing combination shown with GT400 and aux contacts To instantly view a data sheet and specify products, visit www.GavazziOnline.com 100
CC150SA110 价格&库存
很抱歉,暂时无法提供与“CC150SA110”相匹配的价格&库存,您可以联系我们找货
CC150SA110
  • 1+2752.15394
  • 2+2700.33190
  • 4+2648.32850
  • 6+2596.40974
库存:7
