Timers
Multifunction
Type FMB01
Time range 0.05 s to 300 h
Knob selection of time range
Knob adjustable time setting
Knob selection of operating mode (7 functions):
Op - delay on operate
Rb - symmetrical recycler OFF first
R - symmetrical recycler ON first
Id - double interval
Dr - delay on release
In - interval
Io - interval on trigger open
Manual start
Gate and reset inputs
Repeatability: ±0.2% on full scale
Output: 8 A DPDT relay
48 x 48 mm housing for front panel mounting
11 pin socket
LED indication for relay status and power supply ON
Product Description
Ordering Key
Multifunction timer with 7
functions and selectable
time range from 0.05 seconds to 300 hours.
Housing
Function
Type
Item number
Output
Power supply
48 x 48 mm for front panel
mounting and on 11-pin
socket.
FMB 01 D W24
Type Selection
Mounting
Output
Plug
Supply: 12 to 240 VAC/DC
Front or socket
DPDT
11-pin
FMB01DW24
Time Specifications
Output Specifications
Time ranges
Knob selectable
Full scale 12
Output
Rated insulation voltage
Contact ratings (AgSnO2)
Resistive loads
AC 1
DC 12
Small inductive loads AC 15
DC 13
Mechanical life
Electrical life
Full scale 30
Setting accuracy
Repeatability
Time variation
Within rated power supply
Within ambient temperature
Reset
Power supply interruption
Pulse width
0.02
0.2
2
0.2
2
0.2
2
to
to
to
to
to
to
to
1.2s
12s
120s
12min
120min
12h
120h
0.05 to
3s
0.5 to
30s
5
to
300s
0.5 to
30min
300min
to
5
0.5 to
30h
5
to
300h
± 5% on full scale ±50 ms
± 0.2% on full scale or
± 200 ms
≤ 0.05%/V
≤ 0.2%/°C
>100 ms
> 50 ms
Operating frequency
Dielectric strength
Dielectric voltage
≥ 2 kVAC (rms)
Rated impulse withstand volt. 4 kV (1.2/50 µs)
Supply Specifications
Power Supply
Rated operational voltage
2, 10
throuhgt terminals:
Overvoltage cat II
(IEC 60947-1)
12 to 240 VDC + 10% - 15%
12 to 240 VAC + 10% -15%,
45 to 65 Hz
Power consuption
Rated operational power
AC
DC
Specifications are subject to change without notice (21.03.08)
DPDT relay
250 VAC
µ
8 A @ 250 VAC
5 A @ 24 VDC
2.5 A @ 250 VAC
2.5 A @ 24 VDC
≥ 30 x 106 operations
≥ 105 operations
(at 8 A, 250 V, cos ϕ = 1)
≤ 3600 operations/h
3 VA
1.5 W
1
FMB01
General Specifications
Indication for
Power supply On
Output relays ON
Environment
Degree of protection
Operating temperature
Storage temperature
Housing
Dimesions
Material
LED, green
LED, yellow
(flashing when timing)
IP 50 (front panel)
-10 to +55 °C, R.H. < 85%
Weight
Approvals
CE marking
EMC
Immunity
Emission
Timer specifications
Approx. 95 g
UL, CSA
Yes
Electromagnetic Compatibillity
According to EN 61000-6-2
According to EN 61000-6-3
According to EN 61812-1
48 x 48 mm
PA66
Mode of Operation
Function Op
Delay on operate
The time period begins as
soon as the trigger contact
is closed. At the end of the
set delay time the relay
operates
and
doesn’t
release until the power supply is disconnected.
The trigger contact is invalid
while the timer is in operation.
Function Rb
Symmetrical recycler
(OFF first)
soon as the input contact is
closed. The relay is OFF
during the set delay period,
after this time it operates for
the same time period. This
sequence continues with
equal OFF- and ON- time
periods until power supply is
interrupted.
Function R
(ON first)
The relay operates and the
time period begins as soon
closed. After the set delay
period the relay releases for
equal ON- and OFF- time
interrupted.
Function Id
Double interval
as the trigger contact is
closed. The relay releases at
the end of this period or
when the power supply is
disconnected. When the
trigger contact is opened
the relay operates again for
the set delay period. If the
before the end of the first
time period the second one
begins; if the trigger contact
is closed before the end of
the second time period the
relay keeps ON and the first
time period begins again.
Function Dr
Delay on release
The relay operates as soon
closed. The time period
begins when the trigger contact is opened. The relay
releases at the end of the
set delay time or when the
power supply is disconnected. The relay operates again
when the input conctact is
closed again. If it is opened
before the end of the delay
time the relay keeps ON, a
new time period begins as
soon as the contact is
closed again.
operates again when the
trigger contact is closed
again. If the trigger conctact
the delay time, the device
resets and a new time period starts.
Function In
Inteval
Function Io
Inteval on trigger open
opened. The relay releases
at the end of this period or
is opened before the end of
Upper right knob:
Time range selector
12 or 30
Centre knob:
Time setting on absolute
scale
Function and Time Setting
Lower left knob:
Setting of function
(OFF first)
R - simmetrical recycler
(On first)
In - interval
2
Lower right knob:
Time unit selector
0.1s
(0.1 seconds)
sec
(seconds)
10sec (10 seconds)
min
(minutes)
10m (10 minutes)
hrs
(hours)
10h
(10 hours)
FMB01
Range and operation mode selection
Time range selector 12 and 30 at full scale
Scale range display windows
Output indicator (yellow)
(Flashes when timer operates;
on when timer stops operating)
Power indicator (green)
Operating mode selector
(function Op, Rb, R, Id, Dr, In, Io)
Time unit selector (0.1s, sec, 10sec, min, etc.)
Operating mode display window
Time unit display window
Time setting knob (set time)
Operating Diagrams
Function Op - Delay ON Operate
Reset and Gate inputs working mode
If Reset contact is closed the relay is released and timing is
reset. Nothing else happens until Reset is released.
If Gate contact is closed the timing operation is freezed.
When it is released, if timing was in progress, it goes on
from the point reached at the moment of closing the Gate.
Power supply
T
Trigger input
T
Relays ON
LED “POWER”
Power supply
Trigger input
T
T
T
T
T
Relays ON
LED “POWER”
Power supply
Trigger input
T
T
T
T
T
Relays ON
LED “POWER”
Power supply
Trigger input
T
T
T
T
Relays ON
Function Rb - Symmetrical Recycler OFF first
If Reset contact is closed the function is interrupted, the
relay is released and timing is reset. Nothing else happens
If Gate contact is closed while recycling, the timing operation is freezed and the output is kept at the state it was
when Gate has been closed. When it is released, timing
goes on from the point reached at the moment of closing
the Gate.
Function R - Symmetrical Recycler ON first
If Reset contact is closed the function interrupted, the relay
is released and timing is reset. Nothing else happens until
Reset is released.
the Gate.
Function Id - Double interval
LED “POWER”
3
FMB01
Operating Diagrams (cont.)
Function Dr - Delay ON Release
Power supply
T
Trigger input
T
Relays ON
LED “POWER”
Power supply
Trigger input
T
Relays ON
T
T
Function In - Interval
LED “POWER”
Function Io - Interval on trigger open
Wiring Diagrams
4
Dimensions
很抱歉,暂时无法提供与“FMB01DW24”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 2+819.89087
- 3+804.78921
- 国内价格 香港价格
- 1+779.137561+97.36080
- 5+727.231235+90.87460
- 10+683.4635210+85.40540
- 国内价格 香港价格
- 1+1361.349961+170.11389
- 5+1293.292255+161.60942
- 10+1252.4474010+156.50546
- 25+1211.6025525+151.40150
