PD30CNP60NASA
PD30CNP60NASA
    CARLOGAVAZZI
    反射/漫射 光学传感器 236.22"(6m) NPN
PD30CNP60NASA 数据手册
Photoelectrics Retro-reflective, Polarized Type PD30CNP60....SA • • • • • • • • • • • Product Description ThePD30CNP60sensorfamily comes in a compact 10 x 30 x 20 mm reinforced PMMA/ABShousing. The sensors are useful in applications where highaccuracydetectionaswellas smallsizeisrequired. Compact housing and high Miniature sensor range Range: 6 m Sensitivity adjustment by Potentiometer Modulated, red light 625 nm, polarized Supply voltage: 10 to 30 VDC Output: 100 mA, NPN or PNP preset Make and break switching function LED indication for output, stability and power ON Protection: reverse polarity, short circuit and transients Cable and plug versions Excellent EMC performance Ordering Key power LED for excellent performance-sizeratio. The Potentiometer function foradjustmentofthesensitivity makes the sensors highly flexible. The output type is preset(NPNorPNP),andthe output switching function is NOandNCoutput. PD30CNP60NAM5SA Type Housing style Housing size Housing material Housing length Detection principle Sensing distance Output type Output configuration Connection type Sensitivity adjustment Type Selection Housing WxHxD Range Sn 10x30x20mm 6m 10x30x20mm 6m Connection Ordering no. NPN Make and break switching Ordering no. PNP Make and break switching Cable Plug PD 30 CNP 60 NASA PD 30 CNP 60 NAM5SA PD 30 CNP 60 PASA PD 30 CNP 60 PAM5SA Specifications Rated operating distance (Sn)  Ø80mm(ER4)reflector ≤6m ER4060reflector≤4 m Blind zone ≤100mm@Ø80mm(ER4) andER4060reflector Sensitivity Electricaladjustmment 210˚ Mechanicaladjustment 240˚  Temperature drift ≤0.2%/ºC Hysteresis (H) 5%to20% Rated operational volt. (UB) 10to30VDC (rippleincluded) Ripple (Urpp) ≤10% Output current Continuous(Ie) ≤100mA Short-time(I)≤100mA (max.loadcapacity100nF) No load supply current (Io) ≤25mA@UB max Minimum operational current (Im) ≤0.5mA Specificationsaresubjecttochangewithoutnotice(12.12.2012) OFF-state current (Ir) ≤100µA Voltage drop (Ud)≤2VDC@Ie max Protection Short-circuit,reversepolarity andtransients Light source InGaAIP,LED,625nm Light typeRed,modulated Emitter angle ±2º@halfsensing   distance Light spot110mm@1.5meters  Ambient light ≤10,000lux Operating frequency (f)≤1000Hz Response time OFF-ON(tON)≤0.5ms ON-OFF(tOFF) ≤0.5ms Power ON delay (tv) ≤30ms Output function Opencollector NPNorPNPbysensortype Output switching function N.O.andN.C. 1 PD30CNP60....SA Specifications (cont.) Indication OutputON LED,yellow SignalstabilityONand PowerONLED,green.Seecurvefor conditionofstability Environment Installationcategory III(IEC60664/60664A; 60947-1) Pollutiondegree 3(IEC60664/60664A; 60947-1) DegreeofprotectionIP67(IEC60529;60947-1) Ambient temperature Operating -25° to+60°C(-13° to+140°F) Storage -40° to+70°C(-40° to+158°F) Vibration 10to150Hz,1.0mm/15G (IEC60068-2-6) Shock 30g/11ms,3pos,3neg peraxis (IEC60068-2-6,60068-2-32) Rated insulation voltage ≤500VAC(rms) Housing material Body ABSLightGrey FrontglasPMMARed Trimmershaft POMDarkGrey Connection Cable PVC,black,2m 4x0.14mm2,Ø=3.3mm Plug M8,4-pin(CON.54-series) Weight  Cableversion ≤50g Plugversion ≤20g CE-marking Yes ApprovalscULus(UL508+CSA) Operation Diagram tv=PowerONdelay Power supply ON OFF Break Output (N.C.) Present Not Present Tv ON OFF Make Output (N.O.) ON OFF Target Tv Signal Stability Indication Wiring Diagrams NPN 2WH 4BK Excess Gain 1.10 Operation level x 1.10 1.0 0.90 Operation level Operation level x 0.90 Time Green LED ON Yellow LED ON 1BN 3BU PNP 1BN 4BK 2WH 3BU 2 Specificationsaresubjecttochangewithoutnotice(12.12.2012) PD30CNP60....SA Detection Diagram Excess Gain Sensor Y ER4 Reflector 3,0 300 7,9 100 3,9 0 0,0 (mm) 200 -100 -3,9 -200 -7,9 -300 -11,8 0 1 2 3 4 5 Distance (m) 6 7 0,3 100 Excess Gain 0,0 Distance (Feet) Distance (Inches) 6,0 9,0 12,0 15,0 18,0 21,0 24,0 11,8 (Inches) X 3,0 30,00 100,00 10 10,00 1 0,10 1,00 10,00 1,00 Distance (mm) 8 Dimensions Plug version 10.6 20 20 10.6 Cable version Output LED Yellow Power / Stability LED Green 10.6 10.8 17 1.1 Two, 9.5 dia. Lenses Receiver Two M3 15 22 15 30 25.4 Potentiometer Two, 9.5 dia. Lenses 5.5 5.5 Optical axis 5.5 5.5 22 30 Optical axis Potentiometer 7 1.1 Receiver 25.4 10.6 10.8 17 Power / Stability LED Green 7 Output LED Yellow Emitter Emitter Two M3 10.25 Installation Hints To avoid interference from inductive voltage / Relief of the cable strain current peaks, separate the proximity switch cables from any other power cables. E.g. Engine, contactor or solenoid cables Protection of the sensing face Sensor mounted on a mobile carrier Incorrect Incorrect Incorrect Correct Correct > 100 mm The cable should not be pulled A proximity switch should not serve as mechanical stop Any repetitive flexing of the cable should be avoided Accessories Delivery Contents • MountingbracketAPD30-MB1orAPD30-MB2tobe purchasedseparately. • Photoelectricswitch:PD30CNP60... • Screwdriver • Packaging: Plasticbag Specificationsaresubjecttochangewithoutnotice(12.12.2012) 3
PD30CNP60NASA 价格&库存
很抱歉,暂时无法提供与“PD30CNP60NASA”相匹配的价格&库存,您可以联系我们找货
PD30CNP60NASA
  • 1+728.979991+94.42841
