RPYA00424LT
RPYA00424LT
    CARLOGAVAZZI
    SOCKETABLE
    RLY 4PDT 10A 24VDC LED TEST
RPYA00424LT 数据手册
Industrial Relay Type RPY 4 10A Monostable • • • • • • • • • High switching power Wide range of applications 10A switching capacity 4 pole configuration Flanged pins 5mm (0.20”) DC coils from 6 to 220V AC coils from 6 to 380V Compliant with CE low voltage directive TÜV, UL, CSA approved RPY 4 Product Description Ordering Key The RPY relay can be used for a wide range of industrial applications. Available in 1, 2, 3, 4 pole Type Terminal type Contact code Coil code Options change-over contact configuration. Its wide terminals allow reliability big currents. Approvals Terminal type: RPY A 004 A24 DLT A = Plug in terminals, blades B = PCB terminals Box content: 10 relays Box size: (W 240 x D 105 x H 38) mm Weight: 850g (W 9.45 x D 4.13 x H 1.50) inches Weight: 29.99oz E73404 Contact configuration Contact rating Contact code 4 change over contacts (DPDT- 4 form C) 10A 004 Coil Characteristics, DC @ +25°C (+77°F), coil power 1.5W Coil Code 6 9 12 24 36 48 110 120 220 Nominal Voltage VDC 6 9 12 24 36 48 110 115/120 220 Pick-up Voltage VDC 4.5 6.75 9 18 27 36 82.5 86 165 Drop-out Voltage VDC 0.6 0.9 1.2 2.4 3.6 4.8 11 11.5 22 Max. Allowed Voltage VDC 6.6 9.9 13.2 26.4 39.6 52.8 121 132 242 Coil Current mA 250 170 125 70 42 31 16 7.8 7.6 Coil Resistance Ω 24 54 96 360 865 1540 6800 11000* 29000 *coil power 0.9 W 1 Specifications are subject to change without notice. Pictures are just an example. For special features and/or customization, please ask to our sales network. 12/03/15 Industrial Relay Type RPY 4 10A Monostable Coil Characteristics, AC @ +25°C (+77°F), coil power 2.5VA Coil Code A6 A12 A24 A36 A48 A110 A120 A220 A240 A380 Nominal Pick-up Drop-out Max. Allowed Voltage VAC Voltage VAC Voltage VAC Voltage VAC 6 4.8 1.8 6.6 12 9.6 3.6 13.2 24 19.2 7.2 26.4 36 28.8 10.8 39.6 48 38.4 14.4 52.8 100/110 88.0 30.0 121.0 120 96.0 36.0 142.0 220 176 66.0 242.0 240 192 72.0 264.0 380 304 114.0 418.0 Coil Current mA 50Hz 60Hz 420 360 210 180 100 85 70 60 52 44 25/23 21/19.5 20 17 12 10 10 8.5 6.5 5.5 Coil Resistance Ω 5 20 80 180 320 1680 2000 6700 8000 29000 Options Nil D F G = = = = Standard (Fig.1) Free Wheeling diode (DC coil only) Flange Mount (Fig.2) Gold Plated contacts L = LED T = Test Button Note: In case of more options use the alphabetical order for coding. LED and test button are not available on flange mount version Nil (standard) A1 A2 DL /D A1 + - A2 A1 + L - A2 A1 + - A2 Contact Characteristics Contact Rating (With resistive load) Usually rating Material Contact Resistance Current Max. switching current Min. switching current Min. switching current G version 10A – 250VAC 10A-250VAC / 28VDC AgSnO2In2O3 ≤50mΩ Max Switching Power Life Electrical life Mechanical UL/CSA ratings 10A 10mA @ 12VDC 1mA @ 6VDC 2500VA / 280W 1x105 cycles (3600ops/h) 1x107 cycles (18000ops/h) 1/3Hp 120VAC 1/2Hp 240VAC 10A @ 30VDC 10A @ 250VAC Insulation Test voltage(1min.) Between coil and contacts Between open contacts Contact / contact Insulation resistance 2000VAC 1200VAC 1200VAC ≥1000MΩ - 500V Insulation According to EN61810-5 Rated insulation voltage Impulsive insulation Overvoltage categor 250V 2kV II Specifications are subject to change without notice. Pictures are just an example. For special features and/or customization, please ask to our sales network. 12/03/15 2 Industrial Relay Type RPY 4 10A Monostable General Data Nominal coil power Operating time (at nominal voltage) Release time (at nominal voltage) Ambient temperature Ambient humidity Pin View 1.5W DC – 2.5VA AC ≤20ms ≤20ms -25° to +55°C (-13° to +131°F) 35% to 85% Vibration resistance Shock resistance Functional Termination Construction Weight 10 to 55Hz 1mm (0.04”) 98m/s2 (10G) Flanges (blades) 5mm (0.20”) Dust cover 65g (2.29oz) Wiring Diagram mm/inches BOTTOM VIEW RPY 4 10/0.39” 10/0.39” 10/0.39” 3.6/0.14” 1 2 3 4 4.95/0.19” 5 6 7 8 7.15/0.28” 9 13 10 11 12 14 4.6/0.18” - + 14xØ2.5/0.10 30/1.18” PCB version: pin dimension 1.5x0.5mm (0.05”x0.02”) Dimensions mm/inches STANDARD version (Fig.1) 36/1.42” 7/ 0.27” 41.5/1.63” max 28/1.10” max 5/0.20” LATERAL VIEW REAR VIEW BOTTOM VIEW F version (Fig.2) 40/1.57” 41.5/1.63” max 43/1.69” 5/0.20” 3.5/ 0.14” 36/1.42” LATERAL VIEW 3 REAR VIEW BOTTOM VIEW Specifications are subject to change without notice. Pictures are just an example. For special features and/or customization, please ask to our sales network. 12/03/15 Industrial Relay Type RPY 4 10A Monostable Diagrams Max. switching current Electrical Life Electrical life 30 Operating cycles (10 4 ) Switching current (A) 1000 Resistive load AC 10 5 AC (cosϕ = 0.4) DC L/R = 7ms 1 0.5 250VAC Resistance load Resistive load DC 0.1 100 10 0 10 100 0 1000 Switching voltage (V) 2 4 6 8 10 12 14 16 18 20 Switching current Coil temperature rise (°C) Temperature curve of coil 120 100 80 60 40 20 0 70 80 90 100 110 120 130 140 % of Un Bases and Sockets DIN rail sockets code is ZPY14A details and specifications on page 65 of industrial relays catalogue. PCB sockets code is ZY14 details and specifications on page 67 of industrial relays catalogue. Specifications are subject to change without notice. Pictures are just an example. For special features and/or customization, please ask to our sales network. 12/03/15 4
RPYA00424LT 价格&库存
很抱歉,暂时无法提供与“RPYA00424LT”相匹配的价格&库存,您可以联系我们找货
