SPM1121
SPM1121
    CARLOGAVAZZI
    AC/DC CONVERTER 12VDC 10W
SPM1121 数据手册
Modular Switching Power Supply Type SPM 1 DIN rail mounting • • • • • • • • Single DIN module Universal input 90/264VAC – 120/370VDC High efficiency up to 80% Short circuit protection Overload protection Internal input filter LOW voltage LED indicator UL Class 2 Output Product Description Ordering Key SPM Modular switching power supplies are specifically designed in order to satisfy both the Automation and the Building automation application Series Number of DIN modules Output Voltage Phases (only single phase) requirements. The single DIN module PS is capable of up to 10W of output power. Its high efficiency prevents excess of heat in the installation place. SPM 1 - 24 1 Approvals au art geprü f t B p e e T y d Rheinland Product Safety appro v Class 2 Output performances Model Input Voltage Output Power Output Voltage Current Typical Efficiency SPM1-051 SPM1-121 SPM1-151 SPM1-241 90~264Vac 90~264Vac 90~264Vac 90~264Vac 7.5W 10W 10W 10W 5Vdc 12Vdc 15Vdc 24Vdc 1.50A 0.83A 0.67A 0.42A 74% 78% 78% 80% Output data Line regulation Load regulation Output Voltage accuracy Ripple and Noise Temperature Coefficient Hold up time Vi = 115Vac Vi = 230Vac Minimum load Transient recovery time (50% load step changed) 1% max. 1% ±1% 50mV ±0.02%/°C (±0.0112%/°F) 5V and 12V: 10ms 15V and 24V: 60ms 30ms 0% DC ON indicator 5V 12V 15V 24V DC LOW indicator 5V 12V 15V 24V Min. 3Vdc 9Vdc 11Vdc 20Vdc Min. 3.2Vdc 8.8Vdc 12Vdc 21.5Vdc Max. Max. 3.7Vdc 9.3Vdc 12.5Vdc 22Vdc 1ms Specifications are subject to change without notice. Pictures are just an example. For special features and/or customization, please ask to our sales network. 1 Modular Switching Power Supply Type SPM 1 DIN rail mounting Input data Controls and Protections Rated input voltage Voltage range AC in DC in Line frequency Inrush current Vi= 115Vac Vi= 230Vac 100/240VAC 90 - 264 Vac 120 - 370 Vdc 47 - 63Hz Input Fuse Output Short Circuit Rated Overload Protection T1A/250Vac internal* Fold forward 110-160% Typ: 10A Max: 15A Typ: 20A Max: 30A * Not replaceable by user General data (@ nominal line, full load, 25°C ) Insulation voltage 3.000Vac Insulation resistance 100MΩ Ambient temperature -25°C to +71°C (-13°F to 159.8°F) Derating (>61°C to +71°C) 2.5%/°C (1.4%°F) Ambient humidity 90%RH Storage temperature -25°C to +85°C (-13°F to 185°F) Dimensions L x W x D mm 91 x 18 x 55.5 L x W x D inches 3.582 x 0.709 x 2.185 Cooling Case material Weight Protection degree Free air convection Plastic (PC-UL94-V0) 60g IP20 Approvals UL / cUL file: E258355 file: E258395 file: E258396 TUV UL508 listed, UL1310 Class 2 power supply, UL60950-1 Recognized EN60950-1 CE EN61000-6-3, EN55022 class B, EN61000-3-2, EN61000-3-3, EN61000-6-2, EN55024, EN61000-4-2, EN61000-4-3, EN61000-4-4, EN61000-4-5, EN61000-4-6, EN61000-4-8, EN61000-4-11 Block diagrams L Fuse Line Filter N Inrush Current Limiter and rectifier Vo + Switching Device Rectifier Vo Control circuit Opto Isolation Reference & Error Amp. Opto Isolation Over Voltage Detection Output Level Detection 2 Vout ADJ. DC ON ( Green LED) DC LO ( Red LED) Specifications are subject to change without notice. Pictures are just an example. For special features and/or customization, please ask to our sales network Modular Switching Power Supply Type SPM 1 DIN rail mounting Pin assignement and front controls Pin No. 1 2 3 4 LED1 LED2 Designation + L N DC ON DC LOW Description Positive output terminal Negative output terminal Input terminal (phase conductor, no polarity @ DC input) Input terminal (neutral conductor, no polarity @ DC input) Operation indicator LED DC LOW indicator LED Installation Derating Diagram VENTILATION / COOLING: • Normal air convection • 25mm of free space along all sides to allow good cooling CONNECTOR SIZE RANGE: • Solid: 0.2-2.0,mm2 (AWG24-14) (user copper conductors only) Construction Easy snap-on mounting onto the DIN-Rail (TS35/7.5 or TS35/15), unit sits safety and firmly on the rail; no tools required even to remove. Power out (%) 100 90 80 70 60 50 40 30 20 10 0 -25 -20 -15 -10 (-13) (-4) (5) Temperature °C (°F) Mechanical Drawings (mm) 18.00 (0.709) 10.00 (0.394) (14) 10.00 (0.394) 55 60 65 70 75 80 (131) (140) (149) (152) (167) (176) 61 71 (141.8) (159.8) Maximum dimmensions: mm (inch) 45.00 (1.772) 55.5 (2.185) 49.5 (1.948) 32.00 (1.259) 91.00 (3.582) 1 2 67.00 (2.637) L N 3 4 91.00 (3.582) Specifications are subject to change without notice. Pictures are just an example. For special features and/or customization, please ask to our sales network. 3
SPM1121 价格&库存
很抱歉,暂时无法提供与“SPM1121”相匹配的价格&库存,您可以联系我们找货
