ZPY08A
ZPY08A
    CARLOGAVAZZI
    继电器 插口 底座安装
ZPY08A 数据手册
Sockets for RPY Relays ZPY8A 3 1 7 5 4 2 8 6 30/1.18” max mm/inches 2.3/0.09” 27.8/1.09” max 63.8/2.51” max 67.5/2.66” max ZPY8A 35.4/1.39” Rated voltage Rated current Insulation voltage Socket material Socket colour Contact material Terminal type Screw type Max. screw torque Max wire section Operating temperature UL rating UL temperature Drilling pattern 300VAC 16A >2kV PA66 + GF (V0) RAL 7035 / Pantone 1C Nickel Plated - Cu Zn 33 Screw cage M3 with combi head (slotted, Philips Gr.1, Pozi) 1.0N/m 0.5-2.5mm2 (20AWG 14AWG) -25° to +85°C (-13° to +185°F) 10A 300VAC 0° to +60°C (+32° to +140°F) Wiring diagram 26/1.02” ± 0.2/0.008” 4/0.16” ±0.2/0.008” General data 4 3 NO 2 1 NC 8 7 COIL 6 5 COM mm/inches Approvals E73404 Box content: 10 sockets Box size: (W 71 x D 57 x H 150) mm Weight: 480g (W 2.80 x D 2.25 x H 5.90) inches Weight: 16.93oz Optional Accessories (to be ordered separately if required) Hold-down spring steel 1 SZPY 35M (see on page 101) Specifications are subject to change without notice. Pictures are just an example. For special features and/or customization, please ask to our sales network. Optional Springs for ZPY series SZPY 35M General data 5/0.20” 0.25/0.98” Spring material SZPY 35M 7/0.27” 1 plastic bag, 10pcs. ~10g (0.36oz) 0.5/0.02” 1.8/0.7” 50.5/1.99” Packaging Box content: Weight: Stainless steel 0.8/0.31” mm/inches Note: For each realy/socket are required at least 2 springs. Up to 4 springs can be mounted. Specifications are subject to change without notice. Pictures are just an example. For special features and/or customization, please ask to our sales network 2
ZPY08A 价格&库存
很抱歉,暂时无法提供与“ZPY08A”相匹配的价格&库存,您可以联系我们找货
