AC2261
AC2261
    IFM(易福门)
    AS-I INPUT/OUTPUT MODULE, SMARTL
AC2261 数据手册
AC2261 AS-Interface control cabinet module SmartLine25 4DI 4DO A/B T C 1 2 addressing socket COMBICON connector with screw terminals optional Application Design only for operation with AS-i masters with the profile M4 Application Installation in control cabinets Electrical data Operating voltage Max. current consumption from AS-i Additional voltage supply Max. current consumption from additional supply [V] [mA] [V] [mA] Integrated watchdog 26.5...31.6 DC 250 20...30 DC 4000; (AUX) yes Inputs / outputs Number of inputs and outputs Number of digital inputs: 4; Number of digital outputs: 4 Inputs Number of digital inputs 4 Input circuit of digital inputs PNP; (type 2 according to IEC 61131-2) Sensor supply of the inputs AS-i Power supply [V] 18...30; (DC) Max. total current rating of inputs [mA] Input current High [mA] 6...10 Input current Low [mA] 0...2 200 ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — AC2261-00 — 07.10.2021 — AC2261 AS-Interface control cabinet module SmartLine25 4DI 4DO A/B T C Switching level high [V] > 11 Digital inputs protected against short circuits yes Outputs Number of digital outputs 4 Circuit PNP Voltage range DC Max. current load per output Max. current load outputs total [V] 20...30; (AUX) [mA] 1000; (utilisation category DC-12: 700 mA; utilisation category DC-13 (control of electromagnets): 20 W (IEC 60947-5-1)) [A] 4 Short-circuit proof yes Electrically separated yes Actuator supply outputs AUX Operating conditions Ambient temperature [°C] -25...70 Max. relative air humidity [%] 90; (non condensing) Max. height above sea level [m] 2000 Protection IP 20 Pollution degree 2 Tests / approvals EMC EN 61000-6-2 EN 62026-2 EN 50581 MTTF [years] 235 Notes The device shall be supplied from an isolating source.; This voltage source must have a secondary UL-listed fuse (see enclosed sheet).; Alternatively, a class 2 power supply can be used to supply AUX. AS-i classification AS-i version 3.0 AS-i addressing addressing socket Extended addressing mode yes AS-i profile S-7.A.7 AS-i I/O configuration [hex] 7 AS-i ID code [hex] A.7 AS-i certificate 60702 Assignment of the data bits data bit D0 D1 D2 D3 input I-1 I-2 I-3 I-4 Output O-1 O-2 O-3 O-4 Mechanical data Weight [g] Type of mounting Materials 150 mounting on DIN rail PA ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — AC2261-00 — 07.10.2021 — AC2261 AS-Interface control cabinet module SmartLine25 4DI 4DO A/B T C Displays / operating elements Display switching status LED, yellow I1...I4, O1....O4 operation LED, green AS-i, AUX errors LED, red Accessories Accessories (optional) connectors Remarks Remarks Do not connect any of the following points to an external potential: I-, I+, I1, I2, I3, I4 The connections are electrically connected with the AS-i cable. Pack quantity 1 pcs. Electrical connection pin header: Connection A+ AI+ IE+ EI1...I4 O1...O4 O- AS-i + AS-i Sensor supply +24V Sensor supply 0V actuator supply +24V actuator supply 0V switching input sensor 1...4 switching output actuator 1...4 switching output actuator 0V ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — AC2261-00 — 07.10.2021 —
AC2261 价格&库存
很抱歉,暂时无法提供与“AC2261”相匹配的价格&库存,您可以联系我们找货
