AL1422
AL1422
    IFM(易福门)
    IO-LINK MASTER,ETHERNET/IP,8 IO-
AL1422 数据手册
AL1422 IO-Link master with EtherNet/IP interface IO-Link Master PFL EIP 8P IP67 Application Application I/O modules for field applications Daisy-chain function power supply; fieldbus interface Electrical data Operating voltage Current consumption [V] [mA] Protection class Additional voltage supply 20...30 DC; (US ; to SELV/PELV) 300...3900; (US) III [V] 20...30 DC; (UA) [A] 8 Actuator supply UA Max. current load total ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — AL1422-01 — 13.04.2023 — AL1422 IO-Link master with EtherNet/IP interface IO-Link Master PFL EIP 8P IP67 Current rating per port [A] 2; (adjustable: 0...2; Factory setting: 2) Max. current load total [A] 3.6 Current rating per port [A] 2; (adjustable: 0...2; Factory setting: 0,45) Sensor supply US Inputs / outputs Total number of inputs and outputs 16; (configurable) Number of inputs and outputs Number of digital inputs: 12; Number of digital outputs: 12 Inputs Number of digital inputs 12; (IO-Link Port Class A: 4 x 2; IO-Link Port Class B: 4 x 1) Switching level high [V] 11...30 Switching level low [V] 0...5 Digital inputs protected against short circuits yes Outputs Number of digital outputs 12; (IO-Link Port Class A: 4 x 1; IO-Link Port Class B: 4 x 2) Short-circuit proof yes Actuator supply UA Max. current load per output [mA] 2000 [mA] 2000 Sensor supply US Max. current load per output Interfaces Communication interface Ethernet; IO-Link Ethernet - EtherNet/IP Transmission standard 10Base-T; 100Base-TX Transmission rate 10 MBit/s; 100 MBit/s Protocol EtherNet/IP Factory settings IP address: 192.168.1.250 subnet mask: 255.255.255.0 gateway IP address: 0.0.0.0 MAC address: see type label Note on interfaces DHCP, BOOTP, static DLR (Device Level Ring) Supported network topologies: line ring IO-Link Master Transmission type COM1 (4,8 kBaud); COM2 (38,4 kBaud); COM3 (230,4 kBaud) IO-Link revision 1.1 Number of ports class A 4 Number of ports class B 4 Operating conditions Ambient temperature [°C] -25...60 Storage temperature [°C] -25...85 Max. relative air humidity [%] 90 ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — AL1422-01 — 13.04.2023 — AL1422 IO-Link master with EtherNet/IP interface IO-Link Master PFL EIP 8P IP67 Protection IP 65; IP 66; IP 67 Protection rating (NEMA 250) 6P Pollution degree 2 Chemical media ISO 16750-5 AA, BA, BD, HLP, CC, DB, DC, DD, CA NEMA 250 5.13.1 AA Tests / approvals EMC EN 61000-6-2 EN 61000-6-4 Shock resistance DIN EN 60068-2-27 Vibration resistance DIN EN 60068-2-64 2009-04 DIN EN 60068-2-6 2008-10 MTTF [years] 43 [g] 396 Mechanical data Weight Materials housing: PA orange; socket: brass nickel-plated Sealing material FKM Remarks Remarks For further information please see the operating instructions. Pack quantity 1 pcs. Electrical connection Electrical connection - Ethernet Connector: M12; coding: D; Sealing: FKM IN / OUT XF1, XF2 1 2 3 4 5 TX + RX + TX RX not used Electrical connection - Process connection Connector: M12; coding: A; Sealing: FKM ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — AL1422-01 — 13.04.2023 — AL1422 IO-Link master with EtherNet/IP interface IO-Link Master PFL EIP 8P IP67 IO-Link Port Class B X1...X4 1 2 3 4 5 Sensor supply (US) L + actuator supply / digital output (UA) L+ Sensor supply (US) LC/Q IO-Link actuator supply (UA) L- IO-Link Port Class A X5...X8 1 2 3 4 5 Sensor supply (US) L+ digital input (US) Sensor supply (US) LC/Q IO-Link not used Electrical connection - power supply IN Connector: M12; coding: L XD1 1 2 3 4 5 + 24 V DC (US) brown GND (UA) white GND (US) blue + 24 V DC (UA) black FE grey Electrical connection - power supply OUT Connector: M12; coding: L; Sealing: FKM XD2 1 2 3 4 5 + 24 V DC (US) brown GND (UA) white GND (US) blue + 24 V DC (UA) black FE grey ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — AL1422-01 — 13.04.2023 —
AL1422 价格&库存
很抱歉,暂时无法提供与“AL1422”相匹配的价格&库存,您可以联系我们找货
