AL2330
IO-Link CompactLine module
IO-Link Module 6x2 DO M12 IP67
Application
Application
I/O modules for field applications
Electrical data
Operating voltage
Current consumption
[V]
[mA]
Protection class
Additional voltage supply
Max. current consumption
from additional supply
18...30 DC; (US)
50; (US)
III
[V]
[mA]
18...30 DC; (UA)
3600; (UA)
Inputs / outputs
Number of inputs and outputs
Number of digital outputs: 12
Outputs
12; (6 x 2)
Output function
Max. current load per output
Max. current load outputs
total
Electrically separated
PNP
[mA]
[A]
1800
3.6; (Max. current load per output side: 1800 mA)
yes
ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — AL2330-02 — 13.04.2023 —
AL2330
Interfaces
Communication interface
IO-Link
Supported DeviceIDs
Type of operation
DeviceID
Default
893
IO-Link Device
Transmission type
COM2 (38,4 kBaud)
IO-Link revision
1.1
SDCI standard
IEC 61131-9
SIO mode
no
Min. process cycle time
[ms]
5.6
Ambient temperature
[°C]
-25...60
Storage temperature
[°C]
-25...70
Max. relative air humidity
90
Max. height above sea level
[m]
2000
Operating conditions
Protection
IP 65; IP 67
Protection rating (NEMA 250)
6P
Pollution degree
2
Chemical media
ISO 16750-5
AA, BA, BD, HLP, CC, DB, DC, DD, CA
NEMA 250 5.13.1
AA
Tests / approvals
EMC
EN 61000-6-2
EN 61000-6-3
IEC 61131-9
Shock resistance
DIN EN 60068-2-27
Vibration resistance
DIN EN 60068-2-64
DIN EN 60068-2-6
MTTF
[years]
63
[g]
303
Mechanical data
Weight
Dimensions
[mm]
26 x 59.3 x 152
Materials
housing: PA; socket: brass nickel-plated
Sealing material
FKM
Displays / operating elements
Display
operation
LED, green
errors
LED, red
function
LED, yellow
Accessories
Accessories (optional)
Protective caps M12
Remarks
Pack quantity
1 pcs.
AL2330
Electrical connection - IO-Link
Connector: M12; coding: A
X1
1
2
3
4
+ 24 V DC (US)
not used
GND (US)
IO-Link
Electrical connection - Outputs
Connector: M12; coding: A; Sealing: FKM
X1.0...X1.5
1
2
3
4
5
not used
DO2
GND (UA)
DO1
not used
Electrical connection - power supply
X31
1
2
3
4
+ 24 V DC (UAL)
GND (UAR)
GND (UAL)
+ 24 V DC (UAR)
很抱歉,暂时无法提供与“AL2330”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+2357.639911+306.42210
