DP1222
DP1222
    IFM(易福门)
    CONVERTER 0 TO 10 V - IO-LINK, M
DP1222 数据手册
DP1222 Converter 0...10 V - IO-Link Converter 2x0-10V/IO-Link 1 : LED Product characteristics Number of inputs and outputs Number of analogue inputs: 2 Communication interface IO-Link Electrical data Operating voltage [V] 18...30 DC; (to SELV/PELV) Nominal voltage DC [V] 24 Current consumption [mA] < 380 Inputs / outputs Number of inputs and outputs Number of analogue inputs: 2 Inputs Max. total current rating of inputs [mA] Number of analogue inputs Analogue input (voltage) 200 2 [V] 0...10 Interfaces Communication interface Transmission type IO-Link COM2 (38,4 kBaud) IO-Link revision 1.1 SDCI standard IEC 61131-9 Profiles Smart Sensor 0x4000: Identification and Diagnosis 0x8001: Switching Signal Channel 0x8006: Adjustable Switching Signal Channel ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — DP1222-01 — 26.08.2022 — DP1222 Converter 0...10 V - IO-Link Converter 2x0-10V/IO-Link SIO mode no Required master port type A/B Process data analogue 2 Supported DeviceIDs Type of operation DeviceID DP1222 613 DP1222_STATUS_B / CMPT = 2 (Factory setting) 1428 DP1222 / CMPT = 1 Min. process cycle time [ms] 4.3 DP1222_STATUS_B / CMPT = 2 (Factory setting) Min. process cycle time [ms] 4.6 [°C] -25...70 Operating conditions Ambient temperature Note on ambient temperature 2000 m: -25...70 °C 3000 m: -25...64 °C 4000 m: -25...62 °C Storage temperature [°C] -25...70 Max. relative air humidity [%] 90; (linearly decreasing to 50 % (40 °C) non condensing) Max. height above sea level [m] 4000 Protection IP 67 Pollution degree 2 Tests / approvals MTTF [years] 504 Mechanical data Weight [g] 92 Materials housing: PA Displays / operating elements Display operation 1 x LED, green analogue input 2 x LED, yellow Accessories Accessories (optional) mounting clip Remarks Remarks Pack quantity For further information please see the operating instructions. 1 pcs. ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — DP1222-01 — 26.08.2022 — DP1222 Converter 0...10 V - IO-Link Converter 2x0-10V/IO-Link Electrical connection - plug 1: 2: 3: 4: L+ not used LC/Q IO-Link Electrical connection - socket 1: 2: 3: 4: 5: L+ 0...10 V analogue input 2 L0...10 V analogue input 1 not used ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — DP1222-01 — 26.08.2022 —
DP1222 价格&库存
很抱歉,暂时无法提供与“DP1222”相匹配的价格&库存,您可以联系我们找货
