DV2510
DV2510
    IFM(易福门)
    堆叠灯 光纤元件 LED 连接器
DV2510 数据手册
DV2510 5-segment light tower with IO-Link control LED-Tower-5/IOL/Bracket+Buz 1 buzzer Application Application signalling machine conditions Electrical data Operating voltage [V] 18...30 DC; (to SELV/PELV) Nominal voltage DC [V] 24 Current consumption [mA] < 200 [mA] 6 Inputs Input current High ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — DV2510-00 — 22.09.2023 — DV2510 5-segment light tower with IO-Link control LED-Tower-5/IOL/Bracket+Buz Interfaces Communication interface IO-Link Transmission type COM2 (38,4 kBaud) IO-Link revision 1.1 SDCI standard IEC 61131-9 SIO mode yes Required master port type Min. process cycle time A [ms] Supported DeviceIDs 3.2 Type of operation DeviceID Default 841 Operating conditions Ambient temperature [°C] -25...50 Storage temperature [°C] -40...75 Max. relative air humidity [%] 90 Air pressure [kPa] < 106 [m] 2000 Max. height above sea level Protection IP 54 Mechanical data Weight [g] 641 Type of mounting Dimensions Mounting base [mm] Ø 70 / L = 384 Materials housing: ABS; lens: PC Displays / operating elements Display LED segment Acoustic signal Max. sound pressure 5 x 4 LED buzzer [dB] 85 Accessories Accessories (optional) mounting base, E89060 wall bracket, E89061 Mounting adapter, E89063 bracket with lateral cable entry, E89064 mounting tube, E89065 mounting tube, E89066 mounting tube, E89067 Remarks Remarks Pack quantity For further information please see the operating instructions. 1 pcs. ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — DV2510-00 — 22.09.2023 — DV2510 5-segment light tower with IO-Link control LED-Tower-5/IOL/Bracket+Buz Electrical connection - plug Connector: M12; coding: A 1 2 3 4 UB+ not used UBIO-Link (C/Q) Diagrams and graphs wall mounting ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — DV2510-00 — 22.09.2023 — DV2510 5-segment light tower with IO-Link control LED-Tower-5/IOL/Bracket+Buz base mounting ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — DV2510-00 — 22.09.2023 —
DV2510 价格&库存
很抱歉,暂时无法提供与“DV2510”相匹配的价格&库存,您可以联系我们找货
