E30130
E30130
    IFM(易福门)
    WELDING ADAPTER FOR PROCESS SENS
E30130 数据手册
E30130 Welding adapter for process sensors WELDING ADAPT D50/G1 LEAK PORT 1 2 3 G1 internal thread Aseptoflex Vario Leakage port sealing area Application Design with leakage port Installation Pressure rating for thin wall thicknesses [bar] Note on pressure rating 50 for the connection sensor - adapter Tests / approvals Pressure Equipment Directive A possible classification to PED depends on the application and has to be carried out by the user / operator. Pressure Equipment Directive EAC The adapter is intended for use in devices, machines and installations that do not fall under the categories of the technical rule TR CU 032/2013. Safety instructions The compatibility between medium and product material has to be checked in all applications. Mechanical data Weight [g] Materials (wetted parts) 187 stainless steel (1.4435 / 316L) ; surface characteristics : Ra
E30130 价格&库存
很抱歉,暂时无法提供与“E30130”相匹配的价格&库存,您可以联系我们找货
