E40200
E40200
    IFM(易福门)
    ADAPTER SET FOR IFM FLOW METERS,
E40200 数据手册
E40200 Mounting adapter for flow sensors REDADAPT G1/2"-1/2NPT Application Design for flow sensors SM6 MAWP (for applications according to CRN) [bar] 16 Tests / approvals Pressure Equipment Directive A possible classification to PED depends on the application and has to be carried out by the user / operator. Pressure Equipment Directive EAC The adapter is intended for use in devices, machines and installations that do not fall under the categories of the technical rule TR CU 032/2013. Safety instructions The compatibility between medium and product material has to be checked in all applications. Mechanical data Weight [g] Materials 264.5 Adapter: stainless steel (1.4571/316Ti ); Gasket: Centellen 18,5 x 12 x 3 mm Sensor connection G 1/2 Process connection threaded connection 1/2" NPT Sealing flat seal Accessories Items supplied O-rings: 2 Remarks Pack quantity 2 pcs. ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — E40200-00 — 03.12.2007 —
E40200 价格&库存
很抱歉,暂时无法提供与“E40200”相匹配的价格&库存,您可以联系我们找货
