EVC019
EVC019
    IFM(易福门)
    缆线组件 16.40'(5.00m)
EVC019 数据手册
EVC019 Connection cable VDOAH040MSS0005H04STGH040MSS Please see the technical note under "Downloads" Application Special feature Free from silicone; Halogen-free; Gold-plated contacts; Drag chain suitability Free from silicone yes Electrical data Operating voltage [V] Protection class Max. current load total < 250 AC / < 300 DC II [A] 4 [°C] -25...90 Operating conditions Ambient temperature Note on ambient temperature Ambient temperature (moving) cULus: ...75 [°C] Note on ambient temperature (moving) -25...90 cULus: ...75 Storage temperature [°C] -25...55 Storage humidity [%] 10...100 Other climatic conditions for storage according to stated class 1K22/ DIN 60721-3-1 Protection IP 65; IP 67; IP 68; IP 69K Mechanical data Weight [g] Materials 167.7 housing: TPU orange; Sealing: FKM ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — EVC019-01 — 13.04.2023 — EVC019 Connection cable VDOAH040MSS0005H04STGH040MSS Material nut brass, nickel-plated Drag chain suitability Drag chain suitability yes bending radius for flexible use min. 10 x cable diameter travel speed max. 3.3 m/s for a horizontal travel length of 5 m and max. acceleration of 5 m/s² bending cycles > 5 Mio. torsional strain ± 180 °/m Remarks Notes Please see the technical note under "Downloads" Pack quantity 1 pcs. Electrical connection - plug Connector: 1 x M12, straight; coding: A; Locking: brass, nickel-plated; Contacts: gold-plated; Tightening torque: 0.6...1.5 Nm Electrical connection Cable: 5 m, PUR, Halogen-free, black, Ø 4.3 mm; 4 x 0.34 mm² (42 x Ø 0.1 mm ) Connection Electrical connection - socket Connector: 1 x M12, angled; coding: A; Locking: brass, nickel-plated; Contacts: gold-plated; Tightening torque: 0.6...1.5 Nm ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — EVC019-01 — 13.04.2023 — EVC019 Connection cable VDOAH040MSS0005H04STGH040MSS Diagrams and graphs characteristic line for derating Derating Imax * 0.8 (DIN EN 60512-5-2) X Ambient temperature [°C] Y Current [A] ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — EVC019-01 — 13.04.2023 —
EVC019
物料型号:EVC019 器件简介:连接电缆VDOAH040MSS0005H04STGH040MSS 引脚分配:1 1c, 2 2c, 3 3c, 4 4c 参数特性: - 无硅 - 无卤素 - 镀金接触件 - 拖链适用性 - 工作电压:小于250V AC/小于300V DC - 保护等级:IP 65; IP 67; IP 68; IP 69K - 最大电流负载总和:4A - 环境温度:-25...90°C - 存储温度:-25...55°C - 存储湿度:10...100% - 重量:167.7g - 材料:外壳TPU橙色;密封件FKM 功能详解:文档中未提供详细功能描述,但提到了“请查看“下载”下的技术说明”。 应用信息:适用于拖链,弯曲半径为最小10倍电缆直径,最大移动速度为3.3米/秒,最大加速度为5米/秒²,弯曲周期超过500万次,扭转应变为±180°/米。 封装信息:1个M12直头连接器,编码A,锁定件镀镍黄铜,接触件镀金,拧紧扭矩0.6...1.5 Nm。
EVC019 价格&库存
很抱歉,暂时无法提供与“EVC019”相匹配的价格&库存,您可以联系我们找货
