IGM204
IGM204
    IFM(易福门)
    圆柱形,有螺纹-M18
    INDUCTIVE PROXIMITY SENSOR,18MM
IGM204 数据手册
IGM204 Inductive sensor IGK3008BBPKG/M/60V/US-104-DPS Product characteristics Electrical design PNP Output function normally open Sensing range [mm] Housing Dimensions 8 threaded type [mm] M18 x 1 / L = 70 Application Special feature Gold-plated contacts; Increased sensing range Application Use in mobile and harsh applications Electrical data Operating voltage Current consumption [V] [mA] Protection class 10...60 DC < 10 II Reverse polarity protection yes Outputs Electrical design PNP Output function normally open Max. voltage drop switching output DC [V] Permanent current rating of switching output DC [mA] Switching frequency DC [Hz] Short-circuit protection 2.5 200 200 yes Type of short-circuit protection pulsed Overload protection yes Detection zone Sensing range [mm] 8 Operating distance [mm] 0...6.48 Increased sensing range yes ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IGM204-00 — 13.04.2023 — IGM204 Inductive sensor IGK3008BBPKG/M/60V/US-104-DPS Accuracy / deviations Correction factor Hysteresis steel: 1 / stainless steel: 0.7 / brass: 0.5 / aluminium: 0.45 / copper: 0.35 [% of Sr] 1...20 Operating conditions Ambient temperature [°C] -40...85 Protection IP 67; IP 69K Tests / approvals EMC automotive area noise emission and noise interference: ECE R10 E1 type approval noise immunity according to DIN ISO 11452-2 100 V/m conducted interference in 24 V networks to ISO 7637-2: 2004 (pulse 1 to 4) and ISO16750-2: 2012 (load dump) Vibration resistance pulse 1 2a 2b 3a 3b 4 Load dump severity level III III III III III III Test A failure criterion CACAACC EN 61000-4-2 ESD 4 kV CD / 8 kV AD EN 61000-4-3 HF radiated 10 V/m EN 61000-4-4 Burst 2 kV EN 61000-4-5 Surge 0,5 kV mains line to line EN 61000-4-6 HF conducted 10 V EN 55011 class B EN 60068-2-6 Fc 20 g (10...3000 Hz) / -20...50 °C 50 sweep cycles, 1 octave per minute, in 3 axes Shock resistance EN 60068-2-27 Ea 100 g 11 ms half-sine; 3 shocks each in every direction of the 3 coordinate axes / -40...85 °C Continuous shock resistance EN 60068-2-27 40 g 6 ms; 4000 shocks each in every direction of the 3 coordinate axes / -20...50 °C Fast temperature change EN 60068-2-14 Na TA = -40 °C; TB = 85 °C; t1 = 30 min; t2 = < 10 s; 50 cycles EN 60068-2-52 Kb severity level 5 (4 test cycles) Salt spray test MTTF [years] UL approval 1110 Ta 0...40 °C Enclosure type Type 1 power supply Hazardous voltage File number UL E174191 Mechanical data Weight [g] 53.4 Housing threaded type Mounting Dimensions flush mountable [mm] M18 x 1 / L = 70 Thread designation M18 x 1 Materials housing: stainless steel; sensing face: LCP; lock nuts: brass Displays / operating elements Display switching status 4 x 90° LED, yellow ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IGM204-00 — 13.04.2023 — IGM204 Inductive sensor IGK3008BBPKG/M/60V/US-104-DPS Accessories Items supplied lock nuts: 2 Remarks Pack quantity 1 pcs. Electrical connection - plug Connector: 1 x M12; coding: A; Contacts: gold-plated Connection ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IGM204-00 — 13.04.2023 —
IGM204 价格&库存
很抱歉,暂时无法提供与“IGM204”相匹配的价格&库存,您可以联系我们找货
