IGS002
IGS002
    IFM(易福门)
    圆柱形,有螺纹-M18
    INDUCTIVE PROXIMITY SENSOR,18MM
IGS002 数据手册
IGS002 Inductive sensor IGK2012-ARKA/M/LS-104AK Product characteristics Output function Sensing range normally open [mm] Housing Dimensions 12 threaded type [mm] M18 x 1 / L = 70 Application Special feature Gold-plated contacts; Increased sensing range Application Industrial applications / factory automation Electrical data Frequency AC Operating voltage [Hz] 47...63 [V] 20...140 AC/DC Protection class II Reverse polarity protection yes Outputs Output function normally open Max. voltage drop switching output DC [V] Max. voltage drop switching output AC [V] 5.5 5.5 Minimum load current [mA] 5 Max. leakage current [mA] 1 Permanent current rating of switching output AC [mA] Permanent current rating of switching output DC [mA] Short-time current rating of switching output [mA] Switching frequency AC [Hz] 25 Switching frequency DC [Hz] 25 Short-circuit protection Type of short-circuit protection 200 200 1200; (20 ms / 0,5 Hz) yes pulsed ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IGS002-00 — 13.04.2023 — IGS002 Inductive sensor IGK2012-ARKA/M/LS-104AK Overload protection yes Detection zone Sensing range [mm] 12 Real sensing range Sr [mm] 12 ± 10 % Operating distance [mm] 0...9.7 Increased sensing range yes Accuracy / deviations Correction factor steel: 1 / stainless steel: 0.7 / brass: 0.5 / aluminium: 0.4 / copper: 0.3 Hysteresis [% of Sr] 3...15 Switch point drift [% of Sr] -10...10 [°C] -25...70 Operating conditions Ambient temperature Protection IP 67 Tests / approvals EMC MTTF EN 61000-4-2 ESD 4 kV CD / 8 kV AD EN 61000-4-3 HF radiated 10 V/m EN 61000-4-4 Burst 2 kV EN 61000-4-6 HF conducted 10 V EN 55011 class B [years] UL approval 394 Ta 0...40 °C Enclosure type Type 1 power supply Hazardous voltage File number UL E174191 Mechanical data Weight [g] 60 Housing threaded type Mounting non-flush mountable Dimensions [mm] M18 x 1 / L = 70 Thread designation M18 x 1 Materials brass white bronze coated; PBT Displays / operating elements Display switching status 4 x 90° LED, yellow Accessories Items supplied lock nuts: 2 Remarks Pack quantity 1 pcs. ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IGS002-00 — 13.04.2023 — IGS002 Inductive sensor IGK2012-ARKA/M/LS-104AK Electrical connection - plug Connector: 1 x 1/2"; coding: C; Contacts: gold-plated ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IGS002-00 — 13.04.2023 —
IGS002 价格&库存
很抱歉,暂时无法提供与“IGS002”相匹配的价格&库存,您可以联系我们找货
