IGS233
IGS233
    IFM(易福门)
    圆柱形,有螺纹-M18
    SENSOR PROX INDUCTIVE 12MM CYL
IGS233 数据手册
IGS233 Inductive sensor IGK3012-BPKG/US-104 Product characteristics Electrical design PNP Output function Sensing range normally open [mm] 12 [mm] M18 x 1 / L = 60 Housing Dimensions threaded type Application Special feature Gold-plated contacts; Increased sensing range Application Suitable for industrial, mobile, cooling and lubricating applications; Industrial applications / factory automation Electrical data Operating voltage Current consumption [V] [mA] Protection class 10...30 DC < 10 III Reverse polarity protection yes Outputs Electrical design PNP Output function normally open Max. voltage drop switching output DC [V] Permanent current rating of switching output DC [mA] Switching frequency DC [Hz] 2.5 100 300 Short-circuit protection yes Overload protection yes Detection zone Sensing range [mm] 12 Real sensing range Sr [mm] 12 ± 10 % Operating distance [mm] 0...9.72 Increased sensing range yes Accuracy / deviations Correction factor steel: 1 / stainless steel: 0.7 / brass: 0.5 / aluminium: 0.4 / copper: 0.3 ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IGS233-00 — 13.04.2023 — IGS233 Inductive sensor IGK3012-BPKG/US-104 Hysteresis [% of Sr] 3...15 Switch point drift [% of Sr] -10...10 [°C] -40...85 Operating conditions Ambient temperature Protection IP 65; IP 66; IP 67; IP 68; IP 69K Tests / approvals EMC EN 61000-4-2 ESD 4 kV CD / 8 kV AD EN 61000-4-3 HF radiated 10 V/m EN 61000-4-4 Burst 2 kV EN 61000-4-6 HF conducted 10 V EN 55011 class B Vibration resistance EN 60068-2-6 Fc 20 g (10...3000 Hz) / 50 sweep cycles, 1 octave per minute, in 3 axes Shock resistance EN 60068-2-27 Ea 100 g 11 ms half-sine; 3 shocks each in every direction of the 3 coordinate axes Continuous shock resistance EN 60068-2-27 40 g 6 ms; 4000 shocks each in every direction of the 3 coordinate axes Fast temperature change EN 60068-2-14 Na TA = -40 °C; TB = 85 °C; t1 = 30 min; t2 = < 10 s; 50 cycles Salt spray test EN 60068-2-52 Kb severity level 5 (4 test cycles) MTTF [years] 1690 Embedded software included yes UL approval Ta -25...70 °C Enclosure type Type 1 power supply Limited Voltage/Current UL Approval no. A001 File number UL E174191 Mechanical data Weight [g] 50 Housing threaded type Mounting non-flush mountable Dimensions [mm] M18 x 1 / L = 60 Thread designation M18 x 1 Materials brass white bronze coated; sensing face: PBT orange; LED window: PEI; lock nuts: brass white bronze coated Displays / operating elements Display switching status 4 x LED, yellow Accessories Items supplied lock nuts: 2 Remarks Pack quantity 1 pcs. ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IGS233-00 — 13.04.2023 — IGS233 Inductive sensor IGK3012-BPKG/US-104 Electrical connection - plug Connector: 1 x M12; coding: A; Contacts: gold-plated Connection ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IGS233-00 — 13.04.2023 —
IGS233 价格&库存
很抱歉,暂时无法提供与“IGS233”相匹配的价格&库存,您可以联系我们找货
