IGT205
IGT205
    IFM(易福门)
    圆柱形,有螺纹-M18
    INDUCTIVE PROXIMITY SENSOR, 18MM
IGT205 数据手册
IGT205 Inductive sensor IGKC008BASKG/M/V4A/US-104-DRS Product characteristics Electrical design PNP/NPN Output function normally open Sensing range [mm] Housing Dimensions 8 threaded type [mm] M18 x 1 / L = 70 Application Special feature Gold-plated contacts; Increased sensing range; Optical setting aid Application regular cleaning processes Electrical data Operating voltage [V] Protection class 10...36 DC II Reverse polarity protection yes Outputs Electrical design PNP/NPN Output function normally open Max. voltage drop switching output DC [V] 2.8 Minimum load current [mA] 2; (only in 2-wire operation) Max. leakage current [mA] 0.5; (only in 2-wire operation) Permanent current rating of switching output DC [mA] Switching frequency DC [Hz] Short-circuit protection 100 400 yes Type of short-circuit protection pulsed Overload protection yes Detection zone Sensing range [mm] 8 Operating distance [mm] 0...6.48 ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IGT205-02 — 13.04.2023 — IGT205 Inductive sensor IGKC008BASKG/M/V4A/US-104-DRS Increased sensing range yes Accuracy / deviations Correction factor Hysteresis steel: 1 / stainless steel: 0.8 / brass: 0.5 / aluminium: 0.4 / copper: 0.3 [% of Sr] 1...20 [°C] 0...100 Operating conditions Ambient temperature Protection IP 68; IP 69K; ("COP") Tests / approvals EMC MTTF EN 61000-4-2 ESD 4 kV CD / 8 kV AD EN 61000-4-3 HF radiated 10 V/m EN 61000-4-4 Burst 2 kV EN 61000-4-5 Surge 0,5 kV line to line, Ri: 2 Ohm EN 61000-4-6 HF conducted 10 V EN 55011 class B [years] UL approval 1418 Ta 0...40 °C Enclosure type Type 1 power supply Limited Voltage/Current File number UL E174191 Mechanical data Weight [g] 54.8 Housing threaded type Mounting flush mountable Dimensions [mm] M18 x 1 / L = 70 Thread designation M18 x 1 Materials threaded sleeve: stainless steel (1.4404 / 316L); sensing face: PEEK; lock nuts: stainless steel Displays / operating elements Display switching status setting aid Optical setting aid 4 x 90° LED, yellow 1 x LED, red yes Accessories Items supplied lock nuts: 2 Remarks Pack quantity 1 pcs. ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IGT205-02 — 13.04.2023 — IGT205 Inductive sensor IGKC008BASKG/M/V4A/US-104-DRS Electrical connection - plug Connector: 1 x M12; coding: A; Contacts: gold-plated ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IGT205-02 — 13.04.2023 —
IGT205 价格&库存
很抱歉,暂时无法提供与“IGT205”相匹配的价格&库存,您可以联系我们找货
