IGT247
IGT247
    IFM(易福门)
    圆柱形,有螺纹-M18
    INDUCTIVE PROXIMITY SENSOR, 18MM
IGT247 数据手册
IGT247 Inductive full-metal sensor IGK3005-BPKG/AM/US-104 Product characteristics Electrical design PNP Output function Sensing range normally open [mm] Housing Dimensions 5 threaded type [mm] M18 x 1 / L = 70 Application Special feature Gold-plated contacts; Full-metal housing Application Pressure rating constant cleaning with aggressive cleaning agents; regular cleaning processes [bar] Note on pressure rating 100 sensing face Electrical data Operating voltage Current consumption [V] [mA] Protection class 10...30 DC < 20 III Reverse polarity protection yes Outputs Electrical design PNP Output function normally open Max. voltage drop switching output DC [V] Permanent current rating of switching output DC [mA] Switching frequency DC [Hz] Short-circuit protection 2.5 100 100 yes Type of short-circuit protection pulsed Overload protection yes Detection zone Sensing range [mm] 5 Operating distance [mm] 0...4.05 ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IGT247-01 — 13.04.2023 — IGT247 Inductive full-metal sensor IGK3005-BPKG/AM/US-104 Accuracy / deviations Correction factor Hysteresis steel: 1 / stainless steel: 0.7 / brass: 0.7 / aluminium: 0.5 / copper: 0.2 [% of Sr] 1...20 [°C] 0...100 Operating conditions Ambient temperature Protection IP 68; IP 69K Tests / approvals EMC EN 61000-4-2 ESD 4 kV CD / 8 kV AD EN 61000-4-3 HF radiated 10 V/m EN 61000-4-4 Burst 2 kV EN 61000-4-6 HF conducted 10 V EN 55011 emission class B Impact resistance MTTF 1J [years] 1258 Embedded software included yes UL approval Ta -25...70 °C Enclosure type Type 1 power supply Limited Voltage/Current UL Approval no. A012 File number UL E174191 Mechanical data Weight [g] 55 Housing threaded type Mounting Dimensions flush mountable [mm] M18 x 1 / L = 70 Thread designation M18 x 1 Materials Tightening torque housing: stainless steel (1.4404 / 316L); sensing face: stainless steel (1.4404 / 316L); LED window: PEI; lock nuts: stainless steel (1.4404 / 316L) [Nm] 50 Full-metal housing yes Displays / operating elements Display switching status 4 x 90° LED, yellow Accessories Items supplied lock nuts: 2 Remarks Pack quantity 1 pcs. Electrical connection ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IGT247-01 — 13.04.2023 — IGT247 Inductive full-metal sensor IGK3005-BPKG/AM/US-104 Connection Electrical connection - plug Connector: 1 x M12; Contacts: gold-plated ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IGT247-01 — 13.04.2023 —
IGT247 价格&库存
很抱歉,暂时无法提供与“IGT247”相匹配的价格&库存,您可以联系我们找货
