电子发烧友
开通电子发烧友VIP会员 尊享10大特权
海量资料免费下载
精品直播免费看
优质内容免费畅学
课程9折专享价
ID0039
ID0039
    IFM(易福门)
    模块
    INDUCTIVE PROX SENSOR, 50MM FLUS
ID0039 数据手册
ID0039 Inductive sensor IDC2050BARKA/LS-100AK Product characteristics Output function Sensing range normally open [mm] Housing Dimensions 50 rectangular [mm] 92 x 80 x 40 [Hz] 47...63 [V] 20...140 AC / 10...140 DC Electrical data Frequency AC Operating voltage Protection class I Reverse polarity protection yes Outputs Output function normally open Max. voltage drop switching output DC [V] Max. voltage drop switching output AC [V] 6 6 Minimum load current [mA] 5.5 Max. leakage current [mA] 1.7 (140 V AC/DC) Permanent current rating of switching output AC [mA] Permanent current rating of switching output DC [mA] Short-time current rating of switching output [mA] Switching frequency AC [Hz] 25 Switching frequency DC [Hz] 25 450 450 2200; (20 ms / 0,5 Hz) ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — ID0039-00 — 13.04.2023 — ID0039 Inductive sensor IDC2050BARKA/LS-100AK Short-circuit protection yes Type of short-circuit protection pulsed Overload protection yes Detection zone Sensing range [mm] 50 Operating distance [mm] 0...40.5; (mounted flush with mild steel (ST37)) Accuracy / deviations Correction factor steel: 1 / stainless steel: 0.85 / brass: 0.48 / aluminium: 0.46 / copper: 0.38 Hysteresis [% of Sr] 3...20 Switch point drift [% of Sr] -15...15 [°C] -25...70 Operating conditions Ambient temperature Protection IP 67 Tests / approvals EMC EN 60947-5-2 MTTF [years] UL approval 352 Ta 0...40 °C Enclosure type Type 1 power supply Hazardous voltage File number UL E174191 Mechanical data Weight [g] 427 Housing rectangular Mounting Dimensions flush mountable [mm] 92 x 80 x 40 Materials PPE; diecast zinc; brass nickel-plated Displays / operating elements Display switching status 1 x LED, red operation 1 x LED, green short circuit 1 x LED, green/red alternately flashing Accessories Items supplied sealing plug: 1 Remarks Pack quantity 1 pcs. ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — ID0039-00 — 13.04.2023 — ID0039 Inductive sensor IDC2050BARKA/LS-100AK Electrical connection - plug Connector: 1 x 1/2"; coding: C ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — ID0039-00 — 13.04.2023 —
ID0039 价格&库存
很抱歉,暂时无法提供与“ID0039”相匹配的价格&库存,您可以联系我们找货
