IF5539
IF5539
    IFM(易福门)
    圆柱形,有螺纹-M12
    INDUCTIVE PROXIMITY SENSOR,12MM
IF5539 数据手册
IF5539 Inductive sensor IFB3004-BPKG/US-100-DPS Product characteristics Electrical design PNP Output function normally open Sensing range [mm] 4 [mm] M12 x 1 / L = 43 Housing threaded type Dimensions Electrical data Operating voltage Current consumption [V] 10...36 DC [mA] 15; (24 V) Protection class III Reverse polarity protection yes Outputs Electrical design PNP Output function normally open Max. voltage drop switching output DC [V] Permanent current rating of switching output DC [mA] Switching frequency DC [Hz] Short-circuit protection 2.5 150 1500 yes Type of short-circuit protection pulsed Overload protection yes Detection zone Sensing range [mm] 4 Real sensing range Sr [mm] 4 ± 10 % Operating distance [mm] 0...3.25 Accuracy / deviations Correction factor steel: 1 / stainless steel: 0.7 / brass: 0.4 / aluminium: 0.3 / copper: 0.2 Hysteresis [% of Sr] 3...15 Switch point drift [% of Sr] -10...10 ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IF5539-00 — 13.04.2023 — IF5539 Inductive sensor IFB3004-BPKG/US-100-DPS Operating conditions Ambient temperature [°C] -25...80 Protection IP 67 Tests / approvals EMC EN 60947-5-2 EN 55011 MTTF [years] UL approval class B 1134 Ta -25...80 °C Enclosure type Type 1 power supply Limited Voltage/Current File number UL E174191 Mechanical data Weight [g] 24.275 Housing threaded type Mounting non-flush mountable Dimensions [mm] M12 x 1 / L = 43 Thread designation M12 x 1 Materials brass white bronze coated; sensing face: PC Displays / operating elements Display switching status 1 x LED, yellow Accessories Items supplied lock nuts: 2 Remarks Pack quantity 1 pcs. Electrical connection - plug Connector: 1 x M12; coding: A ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IF5539-00 — 13.04.2023 — IF5539 Inductive sensor IFB3004-BPKG/US-100-DPS Connection ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IF5539-00 — 13.04.2023 —
IF5539 价格&库存
很抱歉,暂时无法提供与“IF5539”相匹配的价格&库存,您可以联系我们找货
