IF5579
IF5579
    IFM(易福门)
    圆柱形,有螺纹-M12
    INDUCTIVE PROXIMITY SENSOR, 12MM
IF5579 数据手册
IF5579 Inductive sensor IFA3004-BPKG/US-104 Product characteristics Electrical design PNP Output function normally open Sensing range [mm] Housing 4 threaded type Dimensions [mm] M12 x 1 / L = 80 Application Special feature Gold-plated contacts Electrical data Operating voltage [V] Current consumption [mA] Protection class 10...30 DC 10 III Reverse polarity protection yes Outputs Electrical design PNP Output function normally open Max. voltage drop switching output DC [V] Permanent current rating of switching output DC [mA] Switching frequency DC [Hz] 2.5 200 400 Short-circuit protection yes Overload protection yes Detection zone Sensing range [mm] 4 Real sensing range Sr [mm] 4 ± 10 % Operating distance [mm] 0...3.25 Accuracy / deviations Correction factor steel: 1 / stainless steel: 0.7 / brass: 0.5 / aluminium: 0.4 / copper: 0.3 Hysteresis [% of Sr] 3...15 Switch point drift [% of Sr] -10...10 ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IF5579-01 — 13.04.2023 — IF5579 Inductive sensor IFA3004-BPKG/US-104 Operating conditions Ambient temperature [°C] -25...80 Protection IP 67 Tests / approvals EMC MTTF EN 61000-4-2 ESD 4 kV CD / 8 kV AD EN 61000-4-3 HF radiated 10 V/m EN 61000-4-4 Burst 2 kV EN 61000-4-6 HF conducted 10 V EN 55011 class B [years] 1083 Embedded software included yes UL approval Ta 0...40 °C Enclosure type Type 1 power supply Hazardous voltage UL Approval no. A004 File number UL E174191 Mechanical data Weight [g] 31.6 Housing threaded type Mounting non-flush mountable Dimensions [mm] M12 x 1 / L = 80 Thread designation M12 x 1 Materials brass white bronze coated; sensing face: PBT orange; LED window: PEI; lock nuts: brass white bronze coated Displays / operating elements Display switching status 4 x 90° LED, yellow Accessories Items supplied lock nuts: 2 Remarks Pack quantity 1 pcs. Electrical connection - plug Connector: 1 x M12; coding: A; Contacts: gold-plated ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IF5579-01 — 13.04.2023 — IF5579 Inductive sensor IFA3004-BPKG/US-104 Connection ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IF5579-01 — 13.04.2023 —
IF5579 价格&库存
很抱歉,暂时无法提供与“IF5579”相匹配的价格&库存,您可以联系我们找货
