IF5598
IF5598
    IFM(易福门)
    圆柱形,有螺纹-M12
    INDUCTIVE PROXIMITY SENSOR, 12MM
IF5598 数据手册
IF5598 Inductive sensor IFA2002-FRKG/US-100-IRF Product characteristics Electrical design PNP/NPN Output function normally open / normally closed; (selectable) Sensing range [mm] 2 [mm] M12 x 1 / L = 83 Housing threaded type Dimensions Electrical data Operating voltage [V] Protection class 10...55 DC III Reverse polarity protection yes Outputs Electrical design PNP/NPN Output function normally open / normally closed; (selectable) Max. voltage drop switching output DC [V] 4.6 Minimum load current [mA] 4 Max. leakage current [mA] 0.5 Permanent current rating of switching output DC [mA] Switching frequency DC [Hz] Short-circuit protection 300 1100 yes Type of short-circuit protection pulsed Overload protection yes Detection zone Sensing range [mm] 2 Real sensing range Sr [mm] 2 ± 10 % Operating distance [mm] 0...1.6 Hysteresis [% of Sr] 1...15 Switch point drift [% of Sr] -10...10 Accuracy / deviations ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IF5598-00 — 13.04.2023 — IF5598 Inductive sensor IFA2002-FRKG/US-100-IRF Operating conditions Ambient temperature [°C] -25...80 Protection IP 67 Tests / approvals EMC EN 60947-5-2 EN 55011 MTTF [years] UL approval class B 1815 Ta 0...40 °C Enclosure type Type 1 power supply Hazardous voltage File number UL E174191 Mechanical data Weight [g] 32.7 Housing threaded type Mounting flush mountable Dimensions [mm] M12 x 1 / L = 83 Thread designation M12 x 1 Materials brass white bronze coated; sensing face: PC Displays / operating elements Display switching status 1 x LED, yellow Accessories Items supplied lock nuts: 2 Remarks Pack quantity 1 pcs. Electrical connection - plug Connector: 1 x M12; coding: A ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IF5598-00 — 13.04.2023 —
IF5598 价格&库存
很抱歉,暂时无法提供与“IF5598”相匹配的价格&库存,您可以联系我们找货
