IFT202
IFT202
    IFM(易福门)
    圆柱形,有螺纹-M12
    INDUCTIVE PROXIMITY SENSOR,12MM,
IFT202 数据手册
IFT202 Inductive sensor IFKC007-ASKG/M/V4A/US-104-DRS Product characteristics Electrical design PNP/NPN Output function Sensing range normally open [mm] 7 [mm] M12 x 1 / L = 70 Housing Dimensions threaded type Application Special feature Gold-plated contacts; Increased sensing range; Optical setting aid Application regular cleaning processes Electrical data Operating voltage Current consumption [V] 10...30 DC [mA] 12; (24 V) Protection class II Reverse polarity protection yes Outputs Electrical design PNP/NPN Output function Max. voltage drop switching output DC normally open [V] 2.8 Minimum load current [mA] 2; (only in 2-wire operation) Max. leakage current [mA] 0.5; (only in 2-wire operation) Permanent current rating of switching output DC [mA] Switching frequency DC [Hz] Short-circuit protection 100 700 yes Type of short-circuit protection pulsed Overload protection yes Detection zone Sensing range [mm] 7 Real sensing range Sr [mm] 7 ± 10 % Operating distance [mm] 0...5.7 ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IFT202-00 — 19.06.2007 — IFT202 Inductive sensor IFKC007-ASKG/M/V4A/US-104-DRS Increased sensing range yes Accuracy / deviations Correction factor steel: 1 / stainless steel: 0.7 / brass: 0.5 / aluminium: 0.4 / copper: 0.3 Hysteresis [% of Sr] 3...15 Switch point drift [% of Sr] -10...10 [°C] 0...100 Operating conditions Ambient temperature Protection IP 68; IP 69K Tests / approvals EMC MTTF EN 61000-4-2 ESD 4 kV CD / 8 kV AD EN 61000-4-3 HF radiated 10 V/m EN 61000-4-4 Burst 2 kV EN 61000-4-6 HF conducted 10 V EN 55011 class B [years] UL approval 1287 Ta 0...40 °C Enclosure type Type 1 power supply Limited Voltage/Current File number UL E174191 Mechanical data Weight [g] 29.8 Housing threaded type Mounting Dimensions non-flush mountable [mm] M12 x 1 / L = 70 Thread designation M12 x 1 Materials stainless steel (1.4404 / 316L); sensing face: PEEK Displays / operating elements Display Optical setting aid switching status 4 x 90° LED, yellow setting aid 1 x LED, red yes Accessories Items supplied lock nuts: 2 Remarks Remarks Pack quantity suitable for PLC type 1 according to IEC 61131-2 1 pcs. ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IFT202-00 — 19.06.2007 — IFT202 Inductive sensor IFKC007-ASKG/M/V4A/US-104-DRS Electrical connection - plug Connector: 1 x M12; coding: A; Contacts: gold-plated ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IFT202-00 — 19.06.2007 —
IFT202 价格&库存
很抱歉,暂时无法提供与“IFT202”相匹配的价格&库存,您可以联系我们找货
