IE5090
IE5090
    IFM(易福门)
    圆柱形,有螺纹-M8
    SENSOR PROX INDUCTIVE 1MM CYLIND
IE5090 数据手册
IE5090 Inductive sensor IEB3001-BPKG/US-100-DPS Product characteristics Electrical design PNP Output function normally open Sensing range [mm] 1 [mm] M8 x 1 / L = 53 Housing threaded type Dimensions Electrical data Operating voltage Current consumption [V] 10...36 DC [mA] 15; (24 V) Protection class III Reverse polarity protection yes Outputs Electrical design PNP Output function normally open Max. voltage drop switching output DC [V] Permanent current rating of switching output DC [mA] Switching frequency DC [Hz] 2.5 200 750 Short-circuit protection yes Overload protection yes Detection zone Sensing range [mm] 1 Real sensing range Sr [mm] 1 ± 10 % Operating distance [mm] 0...0.8 Accuracy / deviations Correction factor steel: 1 / stainless steel: 0.7 / brass: 0.4 / aluminium: 0.3 / copper: 0.2 Hysteresis [% of Sr] 1...15 Switch point drift [% of Sr] -10...10 [°C] -25...80 Operating conditions Ambient temperature Protection IP 67 ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IE5090-01 — 21.11.2017 — IE5090 Inductive sensor IEB3001-BPKG/US-100-DPS Tests / approvals EMC MTTF EN 61000-4-2 ESD 4 kV CD / 8 kV AD EN 61000-4-3 HF radiated 3 V/m EN 61000-4-4 Burst 2 kV EN 61000-4-6 HF conducted 3V EN 55011 class B [years] 1376 Embedded software included yes UL approval Ta -25...80 °C Enclosure type Type 1 power supply Class 2 File number UL E174191 Mechanical data Weight [g] 20.7 Housing threaded type Mounting flush mountable Dimensions [mm] M8 x 1 / L = 53 Thread designation M8 x 1 Materials Tightening torque housing: brass white bronze coated; sensing face: PBT [Nm] A = 5 mm: 1 Nm; B: 2 Nm Displays / operating elements Display switching status 1 x LED, yellow Accessories Items supplied lock nuts: 2 Remarks Pack quantity 1 pcs. Electrical connection - plug Connector: 1 x M12; coding: A ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IE5090-01 — 21.11.2017 — IE5090 Inductive sensor IEB3001-BPKG/US-100-DPS Connection Diagrams and graphs Installation ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IE5090-01 — 21.11.2017 —
IE5090 价格&库存
很抱歉,暂时无法提供与“IE5090”相匹配的价格&库存,您可以联系我们找货
