IE5329
IE5329
    IFM(易福门)
    圆柱形,有螺纹-M8
    SENSOR PROX INDUCTIVE 4MM CYLIND
IE5329 数据手册
IE5329 Inductive sensor IEB3004-BPKG/AS Product characteristics Electrical design PNP Output function normally open Sensing range [mm] 4 [mm] M8 x 1 / L = 50 Housing threaded type Dimensions Application Special feature Increased sensing range Electrical data Operating voltage [V] Current consumption [mA] Protection class 10...30 DC < 10 III Reverse polarity protection yes Outputs Electrical design PNP Output function normally open Max. voltage drop switching output DC [V] Permanent current rating of switching output DC [mA] Switching frequency DC [Hz] 2.5 100 800 Short-circuit protection yes Overload protection yes Detection zone Sensing range [mm] 4 Real sensing range Sr [mm] 4 ± 10 % Operating distance [mm] 0...3.25 Increased sensing range yes Accuracy / deviations Correction factor steel: 1 / stainless steel: 0.7 / brass: 0.5 / aluminium: 0.5 / copper: 0.4 Hysteresis [% of Sr] 1...20 Switch point drift [% of Sr] -10...10 ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IE5329-02 — 13.04.2023 — IE5329 Inductive sensor IEB3004-BPKG/AS Operating conditions Ambient temperature [°C] -25...70 Protection IP 65; IP 67; (with ifm socket duly screwed on) Tests / approvals EMC MTTF EN 61000-4-2 ESD 4 kV CD / 8 kV AD EN 61000-4-3 HF radiated 10 V/m EN 61000-4-4 Burst 2 kV EN 61000-4-6 HF conducted 10 V EN 55011 Klasse B [years] 1379 Embedded software included yes UL approval Ta -25...70 °C Enclosure type Type 1 power supply Limited Voltage/Current UL Approval no. A017 File number UL E174191 Mechanical data Weight [g] 15.9 Housing threaded type Mounting non-flush mountable Dimensions [mm] M8 x 1 / L = 50 Thread designation M8 x 1 Materials Tightening torque brass white bronze coated; sensing face: PBT orange; LED window: PPSU; lock nuts: brass white bronze coated [Nm] A = 5 mm: 1,5 Nm; B = 2 Nm Displays / operating elements Display switching status 4 LED, yellow Accessories Items supplied lock nuts: 2 Remarks Pack quantity 1 pcs. Electrical connection - plug Connector: 1 x M8; coding: A ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IE5329-02 — 13.04.2023 — IE5329 Inductive sensor IEB3004-BPKG/AS Connection Diagrams and graphs Installation ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IE5329-02 — 13.04.2023 —
IE5329 价格&库存
很抱歉,暂时无法提供与“IE5329”相匹配的价格&库存,您可以联系我们找货
